remove pcv valve #863878 01/25/08 08:45 PM
wyodriver4 Offline OP
how do you take the pcv valve off? mine seems like its press fitted or something. accidently broke trying to get it out.
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: remove pcv valve [Re: wyodriver4] #863879 01/25/08 09:07 PM
bumpcity76 Offline
I had the same problem. It's pretty brittle plastic. I broke mine off trying to replace it and the "rubber" grommet in the valve cover was plasticky. I also replaced the "rubber" hose attached to the valve (also very hard plastic) with some fuel line I bought from the parts store because I broke the new PCV valve trying to put the original hose back on. You may want to do the same.
Thanks,
Kris
Re: remove pcv valve [Re: bumpcity76] #863880 01/26/08 02:14 AM
thanks. finally got that little project done. ended up having to get the hose like you suggested because i broke the original. whats with all the hoses being made out of that hard plastic? PITA. anyway, thanks again.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5916 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-06-09 21:06:15 UTC
