Page 1 of 3 1 2 3
battery wont charge? #864156 01/27/08 03:24 AM
wyodriver4 Offline OP
ok so i just replaced the plugs and wires and valve cover gasket and got everything put back together and now the battery doesnt seem to take a charge. as soon as you give it any juice it fires right up but as soon as you turn it off it wont start even after an hour of driving. another strange thing is that the clock and radio arent resetting like they usually do with a dead battery. any ideas as to the problem?
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: battery wont charge? [Re: wyodriver4] #864157 01/27/08 07:06 AM
jaybur Offline
if you can drive around for an hour, the battery is charging.
I would guess you have a bad ground, the starter requires the most energy of all. everything else could work like normal but if the ground isn't really good, the starter won't beable to draw enough to start it. Look for bad grounding points from the post on the battery to the main engine/chassis ground from the main ground cable, there you should locate the issue.
Sportage sold.........
1999 4runner 4x4 , Tundra brake rotors and calipers (well worth it!) -wifes
Re: battery wont charge? [Re: jaybur] #864158 01/27/08 03:27 PM
bumpcity76 Offline
I have had issues at the negative post on the battery. I had replaced the terminals and lost some length on the cables. Everything looked ok, but there wasn't a lot of slack on the ground cable. The biggest issue was with the part that clamps onto the cable and bolts to the intake. I guess that whenever the engine would turn over, or the transmission would shift, it was always tugging on the cable. I was having some strange symptoms, so I examined the battery cables. Whenever I touched the ground cable, it just fell out of the terminal. I bought some wire lugs and used a peice of cable to extend the ground point from the intake. The improvement in performance was better than any tune up I had previously performed. Hope this helps.
Re: battery wont charge? [Re: wyodriver4] #864159 01/27/08 06:06 PM
bombardj1 Offline
try cleaning the termenals and posts
Re: battery wont charge? [Re: bombardj1] #864160 01/28/08 01:49 AM
Nukeiridium Offline
If none of the previously mentioned stuff works, maybe look for a drain somewhere, check with an ammeter to see if something is drawing current while the car is shut off. I have had cars where a light was on or the radio or something was drawing current whiel the car sat, thus killing the battery after a few hours.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: battery wont charge? [Re: Nukeiridium] #864161 01/28/08 03:27 AM
jaybur Offline
he said as soon as you shut it off it wont start back up
therefore it has to be related to a bad ground OR a bad positive battery cable to the battery.
that point that he can drive it around means the alternator is working, or the car would make it about 5 minutes or until the battery ran out of power.
Re: battery wont charge? [Re: jaybur] #864162 01/28/08 03:24 PM
Dave Scott Offline
it's the alternator.
a used one from here:
http://4subarusuzukikiaparts.com/
is like 40-60 bucks, i think. and they give you good info, like how many miles on it and whatnot. i've had one in for 8 years and it's never given me one bit of trouble.
Re: battery wont charge? [Re: Dave Scott] #864163 01/28/08 04:12 PM
jaybur Offline
maybe it is but please explain how he can drive it for an hour with a bad alt. but then it just wont start back up. but everything else works....
Re: battery wont charge? [Re: jaybur] #864164 01/28/08 05:25 PM
Dave Scott Offline
that is self explanatory, isn't it? you need 12-14 volts to start a motor, you don't need that much to run a radio, lights, wipers or anything else. if the alternator isn't charging the battery, the voltage is dropping to just below 12-ish while driving, due to headlights being on, using turn signals, computer, abs, auto tranny (maybe?), etc. could just be bad connection, too, but, if not, sounds exactly like a bad alternator.
Re: battery wont charge? [Re: jaybur] #864165 01/28/08 05:27 PM
Hydra747 Offline
You are correct! <img src="/forums/images/graemlins/kewl.gif" alt="" />
The first step is to have a load test to battery for current draw.
And of course check the terminals!
I choose battery as the culprit initially.
Then second do an Alternator bench test regarding the charging sys. ------avg.(12.9-14v) which = 80% of load.
And as some one has already deduced..... it very well could be the - Or + connection (hence check terminals).
Step by step! <img src="/forums/images/graemlins/kewl.gif" alt="" />
I say it is the BATTERY!!!!!!!!!!!!!!! <img src="/forums/images/graemlins/nana.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6385 MB (Peak: 0.7634 MB) Data Comp: Off Server Time: 2026-06-09 21:11:44 UTC
