Gold Stripe Be-Gone #864180 01/27/08 03:41 AM
Witsubishi Offline OP
Hi All,
I don't like the gold sticker stripe along the side of my Montero. Are there any 'easy' ways of removing it?
Thanks.
Bonnie - 1989 Montero LS 4-door, black, loaded, sunroof, dual bouncies, 31" BFGs
Clyde - 1989 Montero LS 4-door, black, loaded, alloys, stock
Re: Gold Stripe Be-Gone [Re: Witsubishi] #864181 01/27/08 03:47 AM
powerRam50 Offline
blow torch <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> or sawzall sorry i cant help myself.
Re: Gold Stripe Be-Gone [Re: powerRam50] #864182 01/27/08 04:17 AM
motero Offline
Color it in with a sharpie. <img src="/forums/images/graemlins/shiner.gif" alt="" />
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Gold Stripe Be-Gone [Re: Witsubishi] #864183 01/27/08 04:36 AM
coletrain777 Offline
You've got a few options if the strip has not been clearcoated over:
1. you can use a heat gun (usually cost around $20 and are used to help remove flooring and house paint, can find them at any wal-mart). If you do go this route make sure and use the lower of the two heat settings and always keep the heat gun moving. Never, I repeat never, keep the heat gun in the same spot for too long unless you like watching your factory paint melt. I use this process all the time to remove decals and pinstripes from vehicles during the paint prep process. It's not hard at all.
2. They make a wheel that goes on your drill that can be used to safely remove the stripe and adhesive that won't burn thru the paint if used correctly. You can get one of these decal removing wheels at most any parts store that carries paint and body supplies.
3. Spend the better part of a weekend using your fingernails and anything else you can to get the stripe off, then using laquer thinner to remove the adhesive. Personally I would opt for one of the first two options.
Hope this helps... Cole
95 Monty Sr 3.5
1973 Datsun 240Z
1972 240z roadster
1969 Ford F-100 shortbed
1972 Ford F-100 longbed
1976 Ford F-250 longbed
1994 Jaguar xj6 vandenplas
2001 Lincoln Navigator
2002 Ford ZX2
Cole
Re: Gold Stripe Be-Gone [Re: motero] #864184 01/27/08 04:44 AM
CapnCrunch Offline
Hair dryer on the hottest setting, gloves for protection from the heat, plastic scraper, and lots of patience. I've removed vehicle decals and stickers that way before. It can be slow, but it works well.
That, or cover it with duct tape. <img src="/forums/images/graemlins/notooth.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Gold Stripe Be-Gone [Re: coletrain777] #864185 01/27/08 05:02 AM
52degrees Offline
I have one of these and have used it many times. It works really well, but it's a lot like a giant eraser. It leaves a big mess on the floor. It sweeps up though.
We used them when I worked at Chevy to take the 3M sticky tape from trim moulding off the doors when we replaced them.
KG6VNX
Re: Gold Stripe Be-Gone [Re: 52degrees] #864186 01/28/08 05:43 PM
daan Offline
"Goo Gone" will take the adhesive off very well without damaging the paint. I de-striped mine (only one side had the stripe anyway <img src="/forums/images/graemlins/confused.gif" alt="" />) by just using a hair dryer on the tape and goo-gone-ing the adhesive after.
Re: Gold Stripe Be-Gone [Re: Witsubishi] #864187 01/29/08 12:42 AM
87_Montero Offline
Is that Russell's car in the background?
DDs:
Projects: 86 Ram50
Re: Gold Stripe Be-Gone [Re: 87_Montero] #864188 01/29/08 01:50 AM
Yup, that's the Raider in the background left. <img src="/forums/images/graemlins/smile.gif" alt="" />
Through the 4-door you can see the red and green Monteros that Clarence (cjsmontero) bought in October. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gold Stripe Be-Gone [Re: daan] #864189 01/29/08 05:22 AM
CapnCrunch Offline
Yeah, I forgot to mention that part. Removing the decal is one thing. Removing the underlying adhesive is another. Goo-gone, OOPS, or other like products work well and are quick.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6340 MB (Peak: 0.7432 MB) Data Comp: Off Server Time: 2026-06-20 18:36:15 UTC
