Max overdrive prices #864436 01/28/08 02:25 AM
DonM Offline OP
So after looking at the alternator thread I e-mailed max overdrive to find out their prices on the timing belt replacement parts. They are way cheaper as far as I can see. What do you guys think of parts from Germany?
Abbotsford japan auto
-Timing belt $85.78
-Timing belt tensioner $67.50
-Balancer belt $62.43
-Balancer belt tensioner $56.48
-Camshaft oil seal $12.00
-Crankshaft oil seal $17.60
-Balanceshaft oil seal (RH) $9.15
-Balanceshaft oil seal (LH) $15.97
-Water pump w/gasket $193.15
-Termostat w/gasket $35.98
Total of: $556
Rockey mountain imports
-timing belt $75
-timing belt tensioner $74
-balancer belt $35
-balancer belt tensioner$58
-camshaft oil seal $11
-crankshaft oil seal $18
-balanceshaft oil seal (rh) $9
-balanceshaft oil seal (lh) $13
-water pump w/gasket $170
-termostat w/gasket $34
Total of: $497
Max overdrive
-timing belt $45áGermany or $65 OEM
-timing belt tensioner $42
-balancer belt $40 Germany or $60 OEM
-balancer belt tensioner $42
-crankshaft oil seal $8 Japan AM or $18 OEM
-balanceshaft oil seal (rh) $8 Japan AM or $12 OEM
-balanceshaft oil seal (lh)á $8 Japan AM or $12 OEM
-Camshaft sealá $8 Japan AM or $14 OEM
-water pump w/gasket $135.00
-termostat w/gasketá $35.00 OEM
Total:á $371 (345 if bought as a package) with AF parts or $435 (404 if bought as a pakage)with some OEM partsá (Package 7% discount on either one) *they give a 7% pakage discount*
1991 MITSUBISHI PAJERO EXCEED
Re: Max overdrive prices [Re: DonM] #864437 01/28/08 07:49 PM
redbull Offline
Interesting! That's big savings with the German parts. I wonder if there are any comments over on POCUK comparing OEM to German?
I already have a few OEM parts from eBay in anticipation of changing everything out this spring. Your research is timely. thanks!
Re: Max overdrive prices [Re: redbull] #864438 01/29/08 12:06 AM
3
39ronin Offline
Use Mardy from the Delica.ca site: PM me for his number he has a Mitsubishi connection for OEM parts from Japan and the Phillipines. He is way better to deal with than the Max guy. He cares about the quality of the stuff he sells. Buy the original Mitsu made in Japan belts they are only about $10 more or so.
Re: Max overdrive prices [Re: DonM] #864439 01/29/08 05:25 AM
Pajerist Offline
I am sure there is a trick with prices.
I needed gasket set (about 12 pieces) for fuel pump. They told me it will be set from Germany, but I found empty box from Italy...
They sold it with one condition, it should be installed by them...
I waited two times for 40-60 minutes, it was not ready. They took Pajero to the secret shop about 100 km away from Richmond...
Interesting, are they willing to sell smth without installation?
Fight for Right to drive from Right!
www.ivoac.ca
Stay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
Re: Max overdrive prices [Re: Pajerist] #864440 01/29/08 06:10 AM
DonM Offline OP
Ya I don't trust them much either (gave me a bad feeling and lied to me). It is just too bad that they are soo much cheaper <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Max overdrive prices [Re: DonM] #864441 02/04/08 07:14 PM
spence121 Offline
DONT DEAL WITH MAX OVERDRIVE! THEY ARE CRIMINALS!
I will have to post a thread on this I think but here is the story. I found an Irmshir edition Isuzu Bighorn that I was really intersted located at thier dealership. I had a friend go lookat it for me since he is on the coast. He took it for a drive and said it seemd to drive OK but there was a noticable hum coming from underneath that he couldn't figure out. He said he really didn't trust the guys at the dealership as they seemd that they were hiding something. It apparently was all safety inspected and ready to be registered and insured. Not trusting them he took the vehicle to his dads mechanic shop to have them inspect it. A quick visual underneath revealed numerous problems including an engine and transmission leak and the most obvious of all and the result of the hum, the transfer case was partially being held on by zip ties. The hum was a misaligned transfer case that would fall off sooner than later im thinking. This is the kind of business that these guys are running.
Good luck if you choose to buy anything from them but thats the kind of practise that should be noted by all.
"WE ARE ALL A PRODUCT OF OUR OWN DECISIONS"
92 Mitsubishi Pajero XR 2.5 TD (SOLD and feeling lost without it)
OME Suspension
American Racing steel Wheels with
Dick Cepek FCII Tires
Re: Max overdrive prices [Re: spence121] #864442 02/04/08 07:17 PM
spence121 Offline
I bought all of the same parts from Terra 2 Imports and it was a little over 400 bucks I think but had the parts within a couple of days. I think they were in between max overdrive and rockymountain for pricing. Contact Nick or Gerry there for a quote. They have been good to me.
OME Suspension
Re: Max overdrive prices [Re: 39ronin] #864443 02/05/08 04:32 AM
DonM Offline OP
Check out Mardy's Prices. For the most part they are great.
Re: Max overdrive prices [Re: Pajerist] #864444 02/12/08 07:12 AM
mdrive Offline
I think you are seriously mistaken, what parts you are talking about? We don't sell any parts that is required installation by us. Looks like you are making up something or dreaming.
Re: Max overdrive prices [Re: spence121] #864445 02/12/08 07:14 AM
mdrive Offline
Before you think this way, why don't you stop by at our shop. If we charge customers arm and leg, it is not fair and if we invest $25,000 in Mitsubishi parts and we are the cheapest you don't like it either, what is your problem man?
Moderated by  4x4Wire, Mudraider
PHP: 7.4.33 Page Time: 2.674s Queries: 16 (0.005s) Memory: 0.6418 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-06-24 20:08:07 UTC
