Re: help on possible purchase [Re: RockRidge] #864776 01/30/08 12:20 AM
BigJim Offline
I feel sure you will find the sniffer test applies to THAT one..
In Texas the larger cities do a sniffer test on 85 and newer 75 to 84 have a visual check of engine components.
Re: help on possible purchase [Re: RockRidge] #864777 01/30/08 12:29 AM
BigJim Offline
Maybe you should contact personally one of the inspection stations you might use and see what your requirements will be.. Whatever else you should insist on a current inspection before purchasing a carbed vehicle in California.
Re: help on possible purchase [Re: BigJim] #864778 01/30/08 12:39 AM
RockRidge Offline OP
Here's what I found on the DMV website:
"In order for your vehicle to receive a Smog Check certificate, it must pass all the following elements:
A visual inspection, in which all required emissions control components and systems are identified, and must appear connected and functional.
A functional inspection, which includes checking the operation of the emissions control warning indicators, ("Check Engine" light), the ignition timing, the gas cap, and the Exhaust Gas Recirculation (EGR) system (if the vehicle is so equipped and a Two-Speed Idle (TSI) test is being performed). A functional check of a vehicleÆs On-Board Diagnostic (OBD) system is also performed on 1996 and newer vehicles. Diagnostic information stored in the vehicleÆs computer is reported on the Vehicle Inspection Report (VIR) that the motorist receives at the end of the Smog Check inspection. OBD information can save time and money when repairs are required.
A tailpipe emissions test, which measures exhaust emissions using a probe inserted into the vehicleÆs tailpipe during testing. Vehicles pass or fail this part of the Smog Check inspection based on established emission standards, sometimes called cutpoints."
It also says that the seller is required to provide the certificate to the seller!
1990 YJ 4.2L Carb, 31x10.5.15, AX-15, Mostly Stock (The Red Sled)
2008 F-350 Superduty 4x4 350 HP/650 TQ (The Tow Beast)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6010 MB (Peak: 0.6544 MB) Data Comp: Off Server Time: 2026-06-17 04:02:27 UTC
