Page 1 of 3 1 2 3
Need some help from all you factory e-locked folks. #86495 08/08/02 06:28 AM
Can anyone tell me where the factory locker ECU is located? I'm trying to figure out if my 4Runner was pre-wired for the factory electric locker. If the bulb is pre-wired, why not the rest of the wiring? Steve told me it was behind the passenger kick panel, so I went and took a picture, and it looks the same as his...
http://www.phorunner.com/temp/DSC00041.JPG
That big hard drive looking unit is labeled "ABS 89540-35112" so it's probably the ABS control unit.
I guess the locker ECU looks like this (taken from Ken Emanuel's page):
http://home.off-road.com/~kemanuel/elocker/ECU_mounted.jpg
EDIT: Converted pictures to links so the page loads faster.
Any input appreciated.
-phong
<small>[ 08 August 2002, 12:20 PM: Message edited by: phong ]</small>
Re: Need some help from all you factory e-locked folks. #86496 08/08/02 01:59 PM
Phong,
It's behind the drivers kick panel near the firewall. It's a small black plastic box about 3 or 4" held in place with one screw. I believe it has one connector.
Pete
Re: Need some help from all you factory e-locked folks. #86497 08/08/02 02:22 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by PI Pedro:
<strong>Phong,
Pete</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Thanks Pete,
Here's a pic of my driver side kick panel:
http://www.phorunner.com/temp/DSC00042.JPG
Zoomed in:
http://www.phorunner.com/temp/DSC00043.JPG
Don't mind all the yellow/green wiring, that's my doing <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> . There's one connector that's hanging loose that's visible in the zoomed in picture. I'm thinking that's for the locker ECU. Can anybody confirm?
Thanks!
-phong
<small>[ 08 August 2002, 12:21 PM: Message edited by: phong ]</small>
Re: Need some help from all you factory e-locked folks. #86498 08/08/02 02:45 PM
<img src="http://www.voicenet.com/~roemerp/81092074.gif" alt="" />
Re: Need some help from all you factory e-locked folks. #86499 08/08/02 02:51 PM
OK folks, I've confirmed that hanging connector is D29, (i.e. the locker wiring harness). We all probably have it! What I need now is some help finding where that locker wiring harness exits the body! This can be easily done by following the locker wiring up and off the diff any takers? <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Thanks so much everybody!
-phong
<small>[ 08 August 2002, 09:53 AM: Message edited by: phong ]</small>
Re: Need some help from all you factory e-locked folks. #86500 08/08/02 03:01 PM
<img src="http://www.voicenet.com/~roemerp/80931917.gif" alt="" />
Re: Need some help from all you factory e-locked folks. #86501 08/08/02 03:04 PM
Mojo_Risin Offline
Phong,
In your pictures above I don't see anything that looks like this: (Sent to me from Ken)
<img src="http://home.earthlink.net/~jmstavola/trailtalk_pics/LockerECU2.jpg" alt="" />
Mojo
Re: Need some help from all you factory e-locked folks. #86502 08/08/02 03:08 PM
You're right, the ECU isn't there, but that loose white plug is for that ECU. Now I just need to check that the rest of the wiring is there. Wish me luck!
-phong
Re: Need some help from all you factory e-locked folks. #86503 08/08/02 03:26 PM
Good Luck!
Re: Need some help from all you factory e-locked folks. #86504 08/08/02 04:04 PM
BoostedInline6 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by phong:
<strong>You're right, the ECU isn't there, but that loose white plug is for that ECU. -phong</strong>
</font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">phong, I can tell you almost without a doubt that plug is for the locker. Even the wire colors look correct. You're pre-wired you lucky bum!!
Ken
2000 4Runner | 5-speed | E-locker | Tundra/OME 2" lift | Stubbs Sliders | Deckplate/TrueFlow |
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6217 MB (Peak: 0.7421 MB) Data Comp: Off Server Time: 2026-06-21 20:31:21 UTC
