Broke a tooth #864996 01/29/08 08:04 PM
Bogo Offline OP
Yeh, I broke a tooth or two. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Haven't felt the pain yet. Unfortunately it will be the wallet that will feel the most pain. <img src="/forums/images/graemlins/scared.gif" alt="" /> I'll just have to bear the brunt of cold temperatures until the tooth is repaired. I only have my JD2555 for doing the feeding with, and it doesn't have a cab. The JD7410 is now in the shop and I'm waiting on their diagnosis as to how bad it is. The symptoms are it will slip in one spot then it will grab and work for a bit, then slip again. I think it is the drivers side bevel gear in the differential, but who knows. At least on that side there is a spot where I can rotate the tire a few inches where in most places it will only rotate less than an inch. The passenger side tire will only rotate less than an inch. If it is what I think it is then I'll have them replace the bevel and pinion gears. Yes it would be cheaper to just replace only the broken gear, but I don't like running old and new gears against each other. The other possibility is I damaged the main spiral bevel gear, but then why am I getting different movements on the wheels.
-- Bryan
Re: Broke a tooth [Re: Bogo] #864997 01/29/08 11:01 PM
8
89IsMine Offline
What the...??? Are you speaking in a language I don't understand??? <img src="/forums/images/graemlins/pfft.gif" alt="" />
Oh. Tractors. John Deere Tractors.
Never mind <img src="/forums/images/graemlins/wink.gif" alt="" />
Eric W.
Re: Broke a tooth [Re: Bogo] #864998 02/02/08 05:58 AM
Bogo Offline OP
Looks like it was not setup properly at the factory. <img src="/forums/images/graemlins/frown.gif" alt="" /> No broken teeth, but the pinion gears were definitely slipping. It will be a couple of days before they get it back together. The parts finally came in late today. And yes, it is a John Deer 7410 tractor and is the front axle, not the rear.
-- Bryan
Re: Broke a tooth [Re: Bogo] #864999 02/02/08 07:36 AM
IceBlueT Offline
i know i might be blasted for sayin this...but i have always, and will always be, an international harvester/farmall man. my family has had them since my grandfater bought a 1950 Cub.
now, my dad has three, i have one, and my brother has one...here they are...
[img]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=10837053&albumID=86001&imageID=12237169[/img]
My dads 1954 Farmall Super MTA...one of 2500 made
[img]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=10837053&albumID=86001&imageID=12236944[/img]
My dads 1956 Farmall 400, LPG head, 55 DBHP (Draw bar horse power)
[img]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=94295665&albumID=0&imageID=13774263[/img]
My Brother's 1952 Farmall Super C
[img]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=94295665&albumID=0&imageID=184009[/img]
My dads 1954 Farmall Super MTA before he restored it
[img]http://viewmorepics.myspace.com/index.cfm?fuseaction=user.editAlbumPhoto&albumID=86001&imageID=28091249&MyToken=0ecf3de3-7993-4ed5-901e-fc6b049f3a89[/img]
This isnt mine, but its just like mine. 1955 Farmall 300. Needs to be restored...burns oil like its goin outta style...lol
No idea why, but they wont show up...copy and paste the URL's to see the pic's...
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Broke a tooth [Re: IceBlueT] #865000 02/02/08 07:46 PM
Bogo Offline OP
This is the first problem I've had with a John Deere tractor that isn't related to being plain worn out from 1000s of hours of use and abuse. I end up fixing allot of other equipment, but the tractors keep going. Thinking about it I've had to repair everything except the JD tractors, Meyers silage wagons, and Heston mower. You have to watch out with that Heston mower. It will mow off T-posts.
-- Bryan
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6074 MB (Peak: 0.6742 MB) Data Comp: Off Server Time: 2026-06-21 15:04:36 UTC
