Something isn't working right. When I turn the key on, I get momentary power to the plugs along with a very fast on/off/on/off clicking of the relay. This last about half a second, then I lose power to the plugs but the dash light stays on for the full 6 seconds or so. Same thing when I turn the key to start.
All relays, dropping resistor, plugs, etc all test out good with a ohm meter. Good charge on the battery, and I even pulled the relays and bench tested them.
My glow plugs worked great with the C223. The only variable is the plugs in this engine as I have it all hooked up as it was originally.
I have a diagram for this engine that shows no dropping resistor, sensing resistor, and only one relay. This is called the QOSII system. It must use 12 volt plugs and I'm pretty sure thats what I have and it is confusing my system that is supposed to have 6 volt plugs.
What I think is happening is the 12 volt plugs are attempting to pull too much power and something senses this and shuts off the power. The dash light staying on until timing out has me confused though.
Soooo.......to make a long story longer, what I am thinking about doing is using the 12 volt plugs (readily availiable here in the US) and an aftermarket controller. I don't want a button. I want everything to appear original unless you know what you're looking for under the hood. Plus some people that may drive this from time to time can't figure out a button.
I found
THIS UNIVERSAL ONE that would work but is kinda bulky. Plus I don't really like how the temp sender attaches. But it's cheap and would work.
Then I thought about
A FORD CONTROLLER. I am familiar with these and have one on my Ford diesel I could take off to experiment with. It's nice and compact and uses a regular temp sender in the water neck. My only concern is that it appears to have a sensing resistor of some sort, and would only having 4 plugs as opposed to the 8 it's designed for cause problems?
Ideas?????
Thanks guys
