DW Question #865406 01/31/08 03:24 AM
fishtaker Offline OP
I got an issue with a violent vibration in the front end at about 45-55 mph. Starts out as a wiggle, then gets worse until I get to about 55. then smooth.
I have done
Tire rotation no change
pull r front and replace with spare no change
pull l front and replace with spare no change
I pulled both tires and got under the jeep on stands and can't find anything loose.
I thought about pulling the front drive shaft to see if it is u-joint related.
Any thoughts?
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: DW Question [Re: fishtaker] #865407 01/31/08 07:54 AM
BobRowe Offline
Before spending a lot of investigative time, I'd put the two best tires on the front and have them dynamically balanced. Then I'd get a front alignment. Then road test it in the same conditions that is now giving a woble. If it still wobbles, then I'd starting looking into a lot of things.
Re: DW Question [Re: BobRowe] #865408 02/02/08 06:00 PM
Got the tires balanced, drives just like new.
Re: DW Question [Re: fishtaker] #865409 02/04/08 07:56 AM
BobRowe Offline
There you go! Glad you got it fixed.
For me personally, every time I have had a vehicle start riding rough at a certain speed, and then get smooth again at a higher speed, it has been caused by tires that were unbalanced.
Get your tires rotated and balanced (at least the front ones) every 5K miles,
Re: DW Question [Re: BobRowe] #865410 02/05/08 02:56 AM
I gotta give props to Discount Tires. They balanced and rotated the tires and set me up for e-mail reminders so I don't forget to get the next rotation.
Great place. in and out in about an hour on Sat.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6039 MB (Peak: 0.6680 MB) Data Comp: Off Server Time: 2026-06-13 02:35:18 UTC
