Ground at ECU
#865414
01/31/08 04:10 AM
OK, replaced the heater fan early this week and found a small ground wire NOT connected where is should be. This wire seems like it should have gone right where the ECU is held by a screw on the passenger side of the ECU. Any clue what it goes to or what it can effect? I re-attached it with seemingly no effect.
Thanks!
97 Montero 90 4-Door Montero RS -- R.I.P.
Re: Ground at ECU
[Re: Skjeflo]
#865415
01/31/08 02:27 PM
Re: Ground at ECU
[Re: Skjeflo]
#865416
01/31/08 05:08 PM
maybe that "no effect" is a good thing? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Ground at ECU
[Re: ghostraider]
#865417
01/31/08 05:47 PM
The ecu ground should be a cluster ground on the passenger footwell outer wall, high. Several wires in the cluster to the ring terminal.
Re: Ground at ECU
[Re: Skjeflo]
#865418
01/31/08 07:53 PM
Possibly this wire from the blower motor resistor? ![[Linked Image]](http://partimages2.genpt.com/partimages/274014.jpg) Eric W.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6062 MB (Peak: 0.6703 MB) Data Comp: Off Server Time: 2026-06-19 06:43:18 UTCValid HTML 5 and Valid CSS
