1996 T100 Parking Brake Light #865916 02/01/08 09:33 PM
T100_4x4 Offline OP
When ever I am accelerating up a hill or just at random times, usually in the same place as the day before, my parking brake light comes on. I know that this can be caused by not having enough brake fluid but I have checked the resivoar and it is pretty damn full. Does anyone know the cause of this problem?
Re: 1996 T100 Parking Brake Light [Re: T100_4x4] #865917 02/01/08 09:46 PM
BamZipPow Offline
Probably the sensor located at the top of the reservoir. I had mine topped as high as it would go and it would slowly fade in and out. I just unplugged it and check my fluids daily.
I guess you could replace yers as well...not sure how much they cost though.
Did you check the wiring on the parking brake switch? <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 1996 T100 Parking Brake Light [Re: T100_4x4] #865918 02/01/08 11:32 PM
J_Bird Offline
Pour in as much fluid as it will hold, without spilling when you put the top back on. That should fix it. Mine has to be to the rim.
Re: 1996 T100 Parking Brake Light [Re: J_Bird] #865919 02/15/08 09:46 PM
T100_4x4 Offline OP
Thanks for the advice, I did this yesterday and it fixed the problem. Strange how the resivor had plenty of fluid but if its just a hair low the light will come on.
Re: 1996 T100 Parking Brake Light [Re: T100_4x4] #865920 02/16/08 07:39 AM
kewlynx Offline
I picked up a '99 Runner last year; does the same thing. It's a lot more touchy about the brake fluid level than my old Toys.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6049 MB (Peak: 0.6692 MB) Data Comp: Off Server Time: 2026-06-07 03:01:18 UTC
