fresh motor wont start!!!!!!!!!!!!! #865987 02/02/08 03:41 AM
E
el_d_m Offline OP
ok here we go. 1993 xj 4 door 4.0 ho . 190,000 miles on her. i dont know alot of her history. ok she threw #1 rod out of the block ( my bad ). my family buisness is a machine shop for rebuilding engines ( not installing ) . we built a new 4.0 with a little extra pep to it just in the head & block. before we pulled the motor i could still start & drive the wounded girl. now with a fresh motor she ran for 15 seconds & ran crappy rough, then she died. we have changed the crank sensor, the ignition switch ( on the steering colum ) , tested all of the relays ( that we could find).
she has spark & awesome fuel pressure. when we put on a timing light it didnt flash bright enough to hardly see & it flashed REALLY slow. pulled the distibutor & retimed the engine. no good & still wierd timing light.
going to check the ecu next.
any ideas? <img src="/forums/images/graemlins/scared.gif" alt="" />
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: fresh motor wont start!!!!!!!!!!!!! [Re: el_d_m] #865988 02/07/08 03:13 AM
E
el_d_m Offline OP
YAY!!!!!!!!!!!!!! ecu fixed it!!!! had a ground wire hooked to a positive & it fried the ecu. so now i have my 4.7 stroker ready to rock out!!!! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5866 MB (Peak: 0.6349 MB) Data Comp: Off Server Time: 2026-06-06 09:23:29 UTC
