Weber installation
#866278
02/03/08 07:27 AM
I have in hand a Weber 32/36 DGAV, with electric choke, which I will be putting on an '86 Montero next summer. I have the carb, complete with adapter plate for the manifold, but I have no instructions on mounting it.
Has anybody written step by step instructions for the process? I've found a couple bits and pieces here and there, but not the complete process.
I need to know what to do with all the vacuum lines, which to block off, which to re-route. I think I've also heard something about water jacket passages, and blocking those.
Has anyone on the forum written what would amount to a tech article on mounting a Weber on the 2.6 engine? Can anyone give me instructions, preferably with pictures?
Thanks for any help.
1989 Trooper, 2.6 1989 Trooper, 2.8 1992 Ford F-350, 7.3 My Photos
Re: Weber installation
[Re: Trooper-san]
#866279
02/03/08 09:31 PM
I can't help you, but I was wondering how do you plan on getting it though the smog test here in SJ? Unless you have a connection, there is no way as most are not approved.
Michael j
TreadLightly! Trainer
[Re: Grasscat]
#866280
02/03/08 09:44 PM
I can't help you, but I was wondering how do you plan on getting it though the smog test here in SJ? Unless you have a connection, there is no way as most are not approved. Like ZZ Top says "...drive that ole Chrysler to Mexico, boy..."
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
[Re: Grasscat]
#866281
02/04/08 12:19 AM
I can't help you, but I was wondering how do you plan on getting it though the smog test here in SJ? Unless you have a connection, there is no way as most are not approved. That particular Montero will never be smogged. It is to be an off-road vehicle in a state where the only inspection is safety rather than smog. It will never see the roads of California. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Trooper-san]
#866282
02/04/08 04:56 AM
There isnt a write up yet. But if ya do a quick search you should find all the info you need! I just installed my weber and it seems to work pretty Good!
SELF MADE CHOP TOP W/HARD TOP.87 5 speed 2.6 less Balance shafts.Raider 88 Rust-O-loomed Body.Herculined Interior.Rust-proofed Frame.(Eastwood Stuff)Prothane Bushings.33x12.50.3in. Body Lift.2in. SHackle Lift + Torsion Crank.
89 Dodge Raider V6 Auto 90 Mitsu Montero LS so Clean!
[Re: Trooper-san]
#866283
02/04/08 02:37 PM
I think the adapter plate blocks off the coolant passage. As for the vacuum...I guess all you'll need is the vac. advance line (which I think gets manifold vacuum) to the distributor and the PCV valve. Calif. vehicles had a second diaphragm on the dist. as well but that doesn't need to be hooked up (i think it gave an extra 5 deg. advance). Everything else can probably get capped/disconnected. Just a guess, someone else who's installed the Weber will probably chime in.
-Todd 1987 Montero 2.6l 5-speed (Sold...but I still miss her) 2008 Jeep Patriot Sport 4x4
[Re: 85Montero]
#866285
02/06/08 06:28 PM
85Montero, many thanks for the scanned instructions. They'll help quite a bit. I think I'm getting a pretty fair idea of what to do now. It shouldn't be too hard a job.
My thanks to all who have responded.
[Re: Trooper-san]
#866286
02/07/08 07:03 PM
Do not rely on the adapter kit to seal off the water hole. The best option that was given to me and worked great was to tap the hole and plug it. Before doing this the hole was shooting antifreeze everywhere. Hope this helps.
[Re: 87BBdriver]
#866287
02/08/08 04:24 AM
I put a Weber 32/36 on my automatic trans 2.6 Raider. Works well and not really difficult to install other than there was no linkage to attach the kick down cable. I had to fab a linkage piece and then all was ok. If yours is a 5 speed, no problem.
