Re: loosing coolant... [Re: BigJim] #866329 02/05/08 02:46 AM
L
ldrdl Offline OP
i tightened the clamp, ill keep an eye on it, thanks!
i think i have a bad pully too. Sometimes when i start it sounds like a bird chirping, then sometimes when i take off from stop it makes a loud whining noise. I replaced the serpentine a couple weeks ago cause it was squeaking, but this is a completely different squeak...
Re: loosing coolant... [Re: ldrdl] #866330 02/05/08 03:17 AM
BigJim Offline
That noise is most likely the idler pully. They have a roller skate bearing in them and all of them go away after a while.
the test is to take the belt off and attempt to wobble and turn the thing by hand if it is any tiny bit loose or you can fell the balls while turning it by hand it has went south and needs a replacement.. The squeal is sorta like a dinner bell...telling you it is time for getting off the couch..
The good part of it is the price..you will love how cheap a new one is.
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.5947 MB (Peak: 0.6430 MB) Data Comp: Off Server Time: 2026-11-18 08:54:48 UTC
