Rating: 5
Page 16 of 51 1 2 … 14 15 16 17 18 … 50 51
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866658 05/26/09 07:30 AM
londart Offline
or i still have a set of warns to get rid of as well if interested
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 69442] #866659 05/27/09 01:51 AM
budicexxx Offline
The guy i got the springs from called me today said i can get his 2" spacers. So what people are saying this is gonna give me 4 inch lift. looks like im gonna have to modify them for the 3". I know i measured the rear tj springs and they are about 12" long. So im gonna go get the spacers friday. Then i guess ill go from there...
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: budicexxx] #866660 05/27/09 05:25 AM
6
69442 Offline
I would confirm what springs you have before messing with the spacers. My tj106 springs are 12" tall as well and they go with the 2" spacer for the 4" lift. Not sure if the tj104 spring is shorter or just has less spring strength so you may have the right equipment already. The rear springs should take less than 20 min to put in so I would just throw them in real quick and see how much lift you have. That way you will know what you have and whether you need to locate new springs or get the 1.5" spacer instead.
If all else fails, get a hold of the guys at upyourkia.com, very helpful info regarding this stuff! <img src="/forums/images/graemlins/cheers.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 69442] #866661 05/27/09 07:53 AM
BAZINGA Offline
Just out of curiosity, I have done a 40mm suspension lift and I have some scuffing from the tires on one side, which is tolerable. Would putting in coil spacers increase the scuffing? Would you need to do something with the panhard rod?
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866662 05/27/09 02:38 PM
6
69442 Offline
I know that as the transverse rod in the rear and yes, you should experience more rubbing with more lift if you don't center the rear axle. Dave Scott makes a adjust kit for this.
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866663 05/28/09 03:06 AM
DEFBOY35 Offline
i would say redoing the panhard rod to recenter the axle would be a good idea with even just the 40mm lift.
or you could always buy the 4" lift (100 mm approx) off of me, and it will come with the adjustable panhard bar!!!
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: DEFBOY35] #866664 05/28/09 03:45 AM
BAZINGA Offline
Not right now thanks. I will keep it in mind though. Right now I have to get another front diff and the left and right drive shaft.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866665 05/29/09 02:26 AM
DEFBOY35 Offline
i also have a front dif available. i have a drivers side used cv, but the passenger side is toast. also warn auto hubs
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: DEFBOY35] #866666 05/29/09 06:31 AM
BAZINGA Offline
I live in a galaxy, far, far, away........from Canada <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: BAZINGA] #866667 05/31/09 01:07 AM
minydigger Offline
how much you want for the hubs
94 Zj custom suspension and other stuff
01 F250 tow hoe 5" exhaust
00'sporty 3" lift 235's
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6507 MB (Peak: 0.7584 MB) Data Comp: Off Server Time: 2026-10-30 10:22:41 UTC
