Rating: 5
Page 18 of 51 1 2 … 16 17 18 19 20 … 50 51
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: k120189] #866678 06/13/09 06:59 PM
Everet Offline
Simple idea! And who said the Greeks went down hill after Plato!!!!
KEVIN: Make sure you tie in your springs and don't overstrech your e-brake cables with the extra travel!!
fokion: Just wish you had pictures of the 3:1 transfer case and gears and how the guy made them, or prints or something....want to build one....maybe even 4:1
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866679 06/13/09 07:02 PM
fokion Offline
I have asked but never got an anwer
bythe way not the same person that is making the lockers made them, it was sb else...
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: fokion] #866680 06/15/09 10:11 PM
budicexxx Offline
I found a set of gabriel rear shocks that are 3 or 3 and a half inches longer than factory.... number on them is 758082. never installed them yet but will this week and it also has the 1/2 inch spacer already compared of the one recomended for the rav4 with 5/8.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: budicexxx] #866681 06/15/09 10:42 PM
Everet Offline
Odd, <img src="/forums/images/graemlins/confused.gif" alt="" /> No such Gabriel Part Number per their web site.... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866682 06/16/09 01:45 AM
budicexxx Offline
sorry maybe its my mistake...i found another number on the shock as i have it in my hand..c00282b1353
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: budicexxx] #866683 06/19/09 08:53 PM
2002_Sporty Offline
Everet: The 3"UPYOURKIA Rocks! Ground clearance much needed.
Fokion: Your design is tight! May have to ask for a set if the offset wheels don't work. I run RAV4 shocks now though.
I Ordered two 15X8 ProComp 98 series steel wheels w/2.5" Backspacing. (Live in Alaska so delivery is 1 month)
Question: Does anyone run this size on the rear. Any issues?
Question: If I run those on the rear and 3.75" Backspacing on the front will I have any issues? Besides front bumper clearance.
Your experience and theorys are much appreciated.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 2002_Sporty] #866684 06/20/09 04:18 AM
Dryver Offline
Sporty,
I'm currently running the 3" UpyourKia Lift with no body lift. I have 31"x10.5"x15" tires on 15 x 8 rims with 3.75" backspacing on all four wheels.
I had to trim the front bumper, flatten the weld seams in the rear of the fender wells and trim the rear of the fender and bottom edge of the inner fender liner to get clearance. I had serious rubbing issues prior to that.
Runs fine now, even off roading. If you go with smaller tires, I don't believe you'll have the rubbing issue.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Dryver] #866685 06/20/09 11:31 AM
2002_Sporty Offline
Dryver: I'm thinking of staying with a smaller diameter for now. Like some 29/10.50-15LT, TSL/SX Super Swampers. I'm not ready for any major body modification yet. But it sounds like an option if it comes to it. Thanks.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 2002_Sporty] #866686 06/21/09 12:59 AM
mattrodd Offline
Would some 215/75R15 or some 225/75R15 tires fit on a stock Sportage. I have a 1996 with stock alloy rims and 205/75R15 tires on it currently. I would like a lift and much larger tires but don't have the money right now.
Here are some pics:
http://i582.photobucket.com/albums/ss268/mattrodd/100_3075.jpg
http://i582.photobucket.com/albums/ss268/mattrodd/100_3076.jpg
http://i582.photobucket.com/albums/ss268/mattrodd/100_3078.jpg
http://i582.photobucket.com/albums/ss268/mattrodd/100_3074.jpg
Thanks
Matt
1996 Sportage EX 4x4
235/75/R15 Tires,
Flow Master
Lift from Everet
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: mattrodd] #866687 06/21/09 01:16 AM
BAZINGA Offline
I run 30 x 9.5 x 15's (240 x 80 x 15') with only a little scuffing on the left side rear shock. I think it's only when I go 4wdriving. Cant' be sure though, I haven't stuck my head out the window to have a look while the car is going. <img src="/forums/images/graemlins/lol.gif" alt="" />
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6526 MB (Peak: 0.7787 MB) Data Comp: Off Server Time: 2026-10-23 16:46:44 UTC
