Rating: 5
Page 36 of 51 1 2 34 35 36 37 38 50 51
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 4runnernomore] #866858 09/25/13 04:13 PM
Davey Offline
Ta Chris, yeah am gonna revert to original springs if/when I get the 2" strut spacers.
Am finding the rear TJ 104 spring to give quite a comfy ride compared to the seemingly stiffer Kings.
Am looking up exactly which rear shocks to go with, the OME site doesn't list any RAV4 items, but AFTER RE READING ALL 35 PAGES OF THIS THREAD, it seems that you got yours via ARB.
Seems stock 1999 RAV4 extended shock length is 617mm which makes for easier searching thru shock catalogues.
I've tried finding Korean links for the extended forks (50mm) and also want a front locker plus 5.38 sets, do you still have any contact info for these??
Dave
Long a$$ 2000 Sporty, auto, 5.38 gears, TF front locker, 4"+ front lift (Kings +40 springs, 50mm spacers, 1.5" diff drop), TJ 104 rears 3" + 50mm coil spacers, 1.5" body lift, 31/10.5r15's on 15x8 Kings (ET-13), WARN manuals, Smart Bar, spotties
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Davey] #866859 09/26/13 12:32 AM
4
4runnernomore Offline
Dave,
Try these contacts:
jinsung.park@colaon.com Trackfinder,NAme is Jin difflocks, adjustable panhard rod ?
picorp@hanmail.net PICORP (Ring and Pinions,difflocks and extended forks Name is Michael
From memory you should be able to source the ring and pinions, extended forks and adjustable panhard rod if required from Michael. In another thread I seen you can now source difflocks through him.
It has been nearly 12 months since people have made contact that I can work out so hopefully the email address's still work.
Hope this info helps and let us know how you go.
Cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 4runnernomore] #866860 09/26/13 06:40 AM
Davey Offline
Onya Chris
Am currently perusing the masterjeep.com site, has all the goodies I'm after, including TrackFinders.
With the extended forks, is it one set needed for both sides, or 2 sets, one for each side?
Does the PICORP contact work for masterjeep?
Dave
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Davey] #866861 09/26/13 11:33 AM
4
I think it's two sets but can't remember as they were sorced for me. Flick them an email to clarify.
cheers, Chris
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 4runnernomore] #866862 09/26/13 06:02 PM
jaybrian32 Offline
Hey all, just thought I'd post a picture of the part number for the Rav4 rear shocks I've just installed, I measured then before fitting and make them to be 660mm at full length.[Linked Image][Linked Image][Linked Image][Linked Image]
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybrian32] #866863 09/27/13 03:13 AM
Davey Offline
Thanks jb <img src="/forums/images/graemlins/kewl.gif" alt="" />
Just a note, shock measurements are taken from the top mounting surface (bottom of the stud) to the eyelet centre, so yours should be roughly 620mm.
I currently have my reaer jacked up <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> with the shock undone, at max travel before the spring falls out is 620mm.
Did you swap the bottom bushing/eyelet from the original shock into these ones?
Cheers
Dave
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Davey] #866864 09/27/13 06:48 PM
jaybrian32 Offline
Cheers
Dave
I did wonder if I had measured them properly, the bottom insert is a Procomp item my mate had kicking around from when he put ES9000's on his lifted Cherokee.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybrian32] #866865 10/02/13 01:53 PM
Davey Offline
I bit the bullet and have ordered a TF front locker and a set of 5.38 gears. <img src="/forums/images/graemlins/zombie.gif" alt="" />
I remember someone on here offering tips for gear setup, still around??!
Do I need to buy a shim kit etc?
I was told that +50mm front forks weren't available, so got creative and made my own 50mm strut spacers - not as straight forward as I'd hoped lol.
With the 50mm spacers installed (standard springs)and at full extension, the outer CV boot rubs on the lower wishbone and the inner rubs on the top fork bolts.
Am I the only person to encounter this problem???
Edit: - I guess if I offset my lower spacer plate (outwards) it'll clear the shaft/forks, but wont help the outer CV/wishbone problem...
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Davey] #866866 10/03/13 12:22 AM
Peabody Offline
Do I need to buy a shim kit etc...
Here's a link to my thread on my diff gear upgrade. It might answer a few questions for you...
5.38 R&P Upgrade!!!
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Davey] #866867 10/04/13 02:51 AM
Davey Offline
NOTE: When jacking the body off an Australian model, DISCONNECT YOUR HEATER HOSES!!!
I kinda might have to replace my heater core now.. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PHP: 7.4.33 Page Time: 1.128s Queries: 16 (0.011s) Memory: 0.6560 MB (Peak: 0.7843 MB) Data Comp: Off Server Time: 2026-05-28 08:05:12 UTC
