Overdrive Question #867138 02/05/08 05:18 AM
L
LAMONTEROGUY Offline OP
Quick question. the Mitsubishi mechanic told me that I should always drive with my overdrive OFF especially when I am on surface streets and rush hour traffic when speeds are below 55/60 mph. He said I should have overdrive on, only when driving above 60 mph. Is this correct? Not that I don't trust the dealer mechanic, but i figure why not confirm his info in the forum.
Marc
1990 Montero LS
Re: Overdrive Question [Re: LAMONTEROGUY] #867139 02/05/08 05:44 AM
DirtDriver Offline
Marc, the only thing that switch does is prevent the transmission from going into 4th gear. This is useful when going up a steep grade and you need the extra engine RPM's to keep your speed up. Also helpful if you want to use engine braking when going down a long grade. The switch doesn't change the transmission shift points between the first, second, and third gears, so it makes no difference in surface street or stop and go driving. Maybe his advice is good for some other vehicle, but not yours. Keep it in O/D all the time except for the above situations.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Overdrive Question [Re: DirtDriver] #867140 02/05/08 06:27 AM
89montero Offline
I leave mine on pretty much all the time on road, if I need more RPMs it usually kicks down automatically.
1989 Montero 4dr V6 3.0l
Re: Overdrive Question [Re: LAMONTEROGUY] #867141 02/05/08 06:42 AM
Kevin C Offline
Sounds like a bit of fear mongering....
The OD on the Auto is pretty tough. Mine typicly kicks into OD at around 45-50 mph. If I'm not going faster than 45 sometimes I turn of the OD so it does not annoy me by shifting in and out a few extra times.
The factor here is its anannoyance and nothing else. I have rebuilt a few of these transmissions and IMHO this is not an issue.
Kevin C
Re: Overdrive Question [Re: Kevin C] #867142 02/05/08 06:01 PM
I think it's worse than just a bad opinion. I have not been able to detect converter lockup in 3rd. This means you have extra heating of the atf from the converter losses. Heating the atf is not a good thing to do...
Re: Overdrive Question [Re: fasteddy] #867143 02/05/08 06:04 PM
hazy_daze Offline
Not sure if the later years are different, but mine does not lock in 3rd.
Re: Overdrive Question [Re: fasteddy] #867144 02/06/08 03:39 AM
Kevin C Offline
The converter lockup valve only works in OD... I have always wanted to check out the valve bodies from other versions of the tranny (Volvo etc) to see if they had that option.
Kevin C
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6144 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-06-21 00:17:21 UTC
