Any ideas on the spring rate #867514 02/06/08 10:23 PM
Chris_Eichman Offline OP
These are NEW TJ springs from Autozone. Any ideas on which spring rates they might be?
Rubicon
http://www.autozone.com/R,APP991530...ype,00798/shopping/partProductDetail.htm
X Model
http://www.autozone.com/R,APP991533...ype,00798/shopping/partProductDetail.htm
Thinking about buying new ones instead of used, if i could figure out what the spring rates were.
Thanks.
Re: Any ideas on the spring rate [Re: Chris_Eichman] #867515 02/06/08 10:27 PM
For some reason it works if you copy and paste it but not if you click it.
Thanks,
Re: Any ideas on the spring rate [Re: Chris_Eichman] #867516 02/07/08 03:00 AM
Everet Offline
Maybe ask them if there are any specs on them. If they are 12.5" tall and 150+ lbs/in they should work. However, why spend that much money? Go on craigslist or e-bay and see if anyone has lifted their TJ and is selling the stock springs. Shouldn't be more than 50 for the rears (probably alot cheaper, got mine for 30 and that was front and rear). Toss/give the fronts away (useless to us and no one wants them) and enjoy the rears. I have the 104's and they are working great and give a good ride.
Good luck,
Re: Any ideas on the spring rate [Re: Everet] #867517 02/07/08 04:01 AM
I think I want the 105's and the best I could find was $50 shipped, so I figured for $20 bucks more it might be worth just getting new ones. The price is for 2 springs by the way.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6016 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-17 15:45:16 UTC
