Where can I get a flex rubber antenna for T-100? #867582 02/07/08 02:44 AM
hogula Offline OP
Now that I am keeping my truck, I want to get it squared away. I hacksawed the top 3 inches off my antenna a few years ago because it was higher than the garage door. Now I have a bigger garage so I want to get an antenna back but I want the flex type so it doesn't snap off if I hit limbs or whatever with it. Any help? Are all antenna bases the same thread?
Hawg
Re: Where can I get a flex rubber antenna for T-100? [Re: hogula] #867583 02/07/08 07:13 AM
BamZipPow Offline
Hawg
Nope... I accidentally broke my antenna off and had to git a quick replacement. I ended up with a $7 Walmart rubbery type one. Works okay in town but out on the road it leaves a lot to be desired. It's only about 14" tall or so...not too bad as it does flex in the wind or when you clean the windshield... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Where can I get a flex rubber antenna for T-100? [Re: hogula] #867584 02/07/08 03:43 PM
Brew Offline
I can't specifically make a product recommendation but be sure what you buy is a base-loaded or electronically-lengthened antenna. The antenna on any vehicle has a length that is determined by the wavelength of the frequencies it's built to receive. A base-loaded antenna will have a coil at it's base that effectively simulates the length of the wire making up the coil if it were to be straightened-out. A shorty antenna without a circuit or coil to emulate the longer mast will not work worth a darn. I would expect such an offering to be in the >$30 range. Brew <img src="/forums/images/graemlins/cheers.gif" alt="" />
98 T100 SR5 4x4 3.4L auto, TRD Goodies, Bilsteins, engine/TC skids, 2" body/d.train lifts, F/R ARBs, 4.56 R&Ps, Aisin hubs, 255/85R16 Dunlop Rover RVXTs (street), 16x7 +8mm offset wheels, custom bumpers, Warn M8000, Master-pull synth. line
Re: Where can I get a flex rubber antenna for T-100? [Re: Brew] #867585 02/07/08 08:12 PM
kustomyoung Offline
The 80s. <img src="/forums/images/graemlins/notooth.gif" alt="" />
1995 Toyota SR5 T100 4x4
2003 Toyota SR5 Tundra 4x4 *SOLD*
1968 Ford Bronco
Re: Where can I get a flex rubber antenna for T-100? [Re: kustomyoung] #867586 02/07/08 08:46 PM
Brew Offline
<img src="/forums/images/graemlins/confused.gif" alt="" /> What do you mean by "The 80s"? Am I missing something? If your talking fractal then nobody makes a product for his application. Brew
Re: Where can I get a flex rubber antenna for T-100? [Re: hogula] #867587 02/07/08 09:13 PM
Brew Offline
This might be a place to start. Linky . Brew <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Where can I get a flex rubber antenna for T-100? [Re: hogula] #867588 02/09/08 03:54 AM
kewlynx Offline
I can't remember how the antenna mount is on the T's-- this is a great article; take a look at the pics and see if that's doable for ya.
Taco whip mod
I hate JCWhitney for getting anything up here. My plugged nickel.
Check for Tacos in your area if it'll work
www.car-part.com <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6191 MB (Peak: 0.7104 MB) Data Comp: Off Server Time: 2026-06-13 03:56:30 UTC
