87 raider with jet valve still will i pass emissons? #867758 02/07/08 10:07 AM
blackmage Offline OP
put a new 5 speed trans new exhaust manifold oil change raid flush
everything sounds and feels find grind in between shifting need to check the oil level in my trans isn't there a pump i need to put more oil in it?
i heard jet valves can case over heating thus warping the head its really taken me awhile to get anything done on this truck because of random family stuff taking my money. can i still pass emissions with them being really old?
sorry about spelling and grammer but its 2 06 am and im like half asleep thought i'd post before i went to bad thank u guys for barein with me <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 87 raider with jet valve still will i pass emissons? [Re: blackmage] #867759 02/07/08 02:26 PM
toddstidham1 Offline
So long as they are sealing and operating correctly, they won't be a factor in whether you pass or fail emissions. The jet valves put a lean mixture of fuel in right at the spark plugs which is supposed to produce more throrough combustion (and thus lower emissions). I had one of my valves break so I put in jet valve eliminators and I still passed emissions with no problems. The condition of your carburetor and catalytic converter as well as the general tune (good plugs/wires/ignition and spark timing) of the engine will play a bigger role in whether you pass or fail.
As for the grinding between shifts, the only time mine grinds (and mine has 151k miles on it) is when it's really cold. The gear oil is just too thick at low temperatures and doesn't flow smoothly enough. Once warmed up enough, usually about a mile or so, it shifts smooth with no grinding (unless I try to speed shift it...these things weren't made for drag racing).
Good luck on the test! <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: 87 raider with jet valve still will i pass emissons? [Re: toddstidham1] #867760 02/11/08 08:32 AM
i'm planing to do clutch and what ever else might need to be done i'm taking her to a shop and will post what they say
with 128 if i'm not wrong on the engine its pretty clean for sitting 2 years could be why i grind. It has been cold lately in Colorado. No smoke carb looks ok everything attached well don't make any smells. Just a werid jet like sound? i never seen another one so i don't know if its normal engine sound. I haven't got it past 55 - 60 was kind of hassleing to but i think i had no air filter? lmao for about a mile.
first car how can i tell faulty parts?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5938 MB (Peak: 0.6483 MB) Data Comp: Off Server Time: 2026-06-17 01:59:46 UTC
