Half shoe box of warn out parts #868097 02/09/08 12:13 PM
Bogo Offline OP
on friday I finally got my John Deere 7410 tractor back with a half shoe box full of warn out parts. The replacement parts only cost a measly $3,500. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> Basically the whole differential core was heavily warn out. It was the opinion of tech who did the work that the differential should never had warn out so fast, it had less than 2500 hours on it. He figured it likely suffered from two problems. First it wasn't setup correctly at the factory, and second it wasn't lubed with the right oil. The oil in it was the original oil that we received it with. At some point they switched to using transmission hydraulic fluid rather than the 70-140 weight it had in it.
-- Bryan
Re: Half shoe box of warn out parts [Re: Bogo] #868098 02/09/08 06:18 PM
LRJ4x4 Offline
Yikes, how much is that thing new?
Re: Half shoe box of warn out parts [Re: LRJ4x4] #868099 02/09/08 07:38 PM
Bogo Offline OP
Without looking at my records, $65,000 with 740 series loader in 2002. It would be a little over $100,000 to get the same tractor now.
-- Bryan
Re: Half shoe box of warn out parts [Re: Bogo] #868100 02/11/08 05:14 PM
I have some issues with Deere. Once had a 690B trackhoe that wore out the engine. Bought a new long block from Deere and installed it, and it blew all the oil out in less than 5 hours and died. Deere declined to honor the warranty. Apparently we were supposed to know that we had to plug some crankshaft drillings that were open in other uses of the engine. Didn't bother to give us the data sheet with the engine. Claimed we should have have the dealer install the engine. They lost the law suit big time...
Re: Half shoe box of warn out parts [Re: fasteddy] #868101 02/12/08 04:32 AM
52degrees Offline
Good greif! I should hope so.
KG6VNX
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6064 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-06-20 13:22:17 UTC
