water temp warning light on 22R? (PIC) #868609 02/12/08 08:27 AM
haulie Offline OP
Well...., I looked around in the arcives and did'nt find any info about putting in a water temp warning light.
A while back I burst a rotten radiator hose and warped the head. The thing is there was'nt any dramatic cloud of steam or any thing to alert me. I was driving along and the truck began losing power, I looked at my water temp gage (SR5 gage cluster) to see it was pegged!
I'm thinking if I would of had a big red light letting me know the water temp was at 200+f I may have avoided the damage.
I'm looking at a sender that's 1/2-14NPT, off at 170f/on at 200f. sender
So, the question is, where do I put the sender? It looks like there is a plug right near the thermostat neck.
Anyone do this before? Any suggestions?
I'm looking at the fitting just below and to the left of the thermostat neck.
Re: water temp warning light on 22R? [Re: haulie] #868610 02/12/08 05:00 PM
dcg9381 Offline
The 22RTE truck had a thermo spout with NPT (or close enough) fitting built in. You could drill and tap them.
The downside is that if you don't have enough water flow, you'll read hotter than you are.. but that maybe good for your purposes.
Another alternative would be to use the existing gauge sender. As long as you have a high impedance circuit that you're using to drive your warning light, it shouldn't impact that reading on the gauge... You'd need basic knowledge of analog electronics.
22REturbo.net
1988 4Runner
Re: water temp warning light on 22R? [Re: dcg9381] #868611 02/12/08 05:24 PM
haulie Offline OP
Hmmm, my knowledge of analog electronics is a little thin....I'm looking for something in the realm of 'plug and play'
Re: water temp warning light on 22R? [Re: haulie] #868612 02/13/08 02:07 AM
Buck Offline
That's where I put the sender for my water temp. gauge, seems to work fine. Not sure what the thread size was, I have a autometer sport edition mechanical gauge. <img src="/forums/images/graemlins/kewl.gif" alt="" />
84 Ext. Cab Pickup.
Re: water temp warning light on 22R? [Re: haulie] #868613 02/13/08 02:45 AM
KiwiCowboy Offline
Most of the sensor pipe threads are British Standard Pipe (BSP) threads. Between 1/16 up to 3/8, they differ by 1 additional thread over U.S. NPT. A NPT sender will screw into a metric hole for a few turns but will end up cross threading after 2 full turns. From the 1/2 NPT on up, they are the same threads per inch but the taper is different.
If a BSP to NPT (metric to U.S. NPT) adapter is not available, you can drill out the hole for the next size NPT and re-thread it then use a brass bushing if necessary.
NPT BSP
1/16-27 1/16-28
1/8-27 1/8-28
1/4-18 1/4-19
3/8-18 3/8-19
1/2-14 1/2-14
3/4-14 3/4-14
1-14 1-14
Re: water temp warning light on 22R? [Re: KiwiCowboy] #868614 02/13/08 07:12 PM
haulie Offline OP
NPT BSP
1/16-27 1/16-28
1/8-27 1/8-28
1/4-18 1/4-19
3/8-18 3/8-19
1/2-14 1/2-14
3/4-14 3/4-14
1-14 1-14
Thanks for the info <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6106 MB (Peak: 0.6980 MB) Data Comp: Off Server Time: 2026-11-15 02:07:14 UTC
