Help, knocking noise. #868885 02/13/08 04:56 AM
Misha80 Offline OP
Did a couple of searches and didn't find anything, but I may be inept at that <img src="/forums/images/graemlins/wink.gif" alt="" /> When slowing down in my cherokee it has started making a knocking noise. Sounds like it's coming from the rear of the jeep. Doesn't change with break application. Doesn't change if I put it in to neutral. I'm hoping it's not the diff. I know how vague this is but I was hoping it would sound familiar to someone smile Oh, stock 98 5.9 btw.
TIA
Mikhail
98 Grand Cherokee 5.9 (Using 10% of the nations gas daily)
95 F-250 (The other 90% of the gas)
95 Honda Del Sol V-tec (Corner Carver)
Re: Help, knocking noise. [Re: Misha80] #868886 02/13/08 05:32 AM
BobRowe Offline
Before checking out the diff, I'd crawl under the Jeep and really check out the driveshaft. Try to move it laterally, and up and down, to check for worn U-joints. ANY movement is suspect. U-joints are cheap (about $20 each) and easy to replace, so there's no point in living with one that you suspect may be loose. Some people replace theirs every 2 to 5 years anyway. Check that first, and then get back to us.
Re: Help, knocking noise. [Re: BobRowe] #868887 02/14/08 06:18 PM
Misha80 Offline OP
Loose lug nuts......grabbed the wheel and it was moving just a bit if I pushed/pulled on it. scary...
Re: Help, knocking noise. [Re: Misha80] #868888 02/15/08 05:18 AM
BobRowe Offline
Good find. Most of us forget to check them periodically, especially after changing a wheel.
Re: Help, knocking noise. [Re: BobRowe] #868889 02/24/08 07:23 AM
E
el_d_m Offline
this may sound stupid but i had the same issue with a 93 xj last year. turned out the lug nuts were loose. tightened them twice a week. the actual problem was the carrier going out. come to find out that chrysler corperate axles tend to get cracks in the carriers & that just goes down hill. i swapped it out with a dana 44 but you can just rebuild it cheap for like $100 or so . or lock it for $200. just food for thought
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
PHP: 7.4.33 Page Time: 6.337s Queries: 15 (0.004s) Memory: 0.6056 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-06-17 01:00:04 UTC
