Page 2 of 5 1 2 3 4 5
Re: 89 3,0L Starting Problem [Re: PatrickS] #869275 02/16/08 12:59 AM
PHIL_ Offline
Did you try querying the ecu to see if any codes are stored? You can do it yourself with a voltmeter:
http://www.4x4wire.com/mitsubishi/tech/FI_troubleshooting/
Re: 89 3,0L Starting Problem [Re: PHIL_] #869276 02/16/08 01:38 AM
FrankR Offline
I might lose, but I'd bet money that the ignition switch is going bad. I'd replace the electrical (rear) portion of the key switch (includes the pigtail connector) - it's an easy job and only costs about $18 for the electrical portion of the switch.
Frank
Re: 89 3,0L Starting Problem [Re: FrankR] #869277 02/17/08 02:48 PM
conner Offline
Frank
From what he is descibing, it sounds like a winner to me.
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: 89 3,0L Starting Problem [Re: conner] #869278 02/18/08 04:48 AM
ditto
Re: 89 3,0L Starting Problem [Re: PHIL_] #869279 02/21/08 10:53 AM
PatrickS Offline OP
No, not yet but will try it. The last few days it has started and ran good. Today started and ran good but while driving, lost power for short time twice.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: 89 3,0L Starting Problem [Re: FrankR] #869280 02/21/08 10:55 AM
PatrickS Offline OP
Thanks. Will check it out but something new has been added to the problem. The last few days it has started and ran good. Today started and ran good but while driving, lost power for short time twice. Could this still be the ignition switch? Is it possible that if the ignition switch is bad, that the starter turns over but there is no spark to coil?
Re: 89 3,0L Starting Problem [Re: PatrickS] #869281 02/21/08 12:55 PM
FrankR Offline
Yes.
Yes. Coil current and starter solenoid switch current are separate circuits within the switch. The starter solenoid switch only gets current when the switch is in the START position. Coil current is provided in both START and RUN positions. Your switch is likely carbon fouled where the switch makes contact as it rotates to include the starter solenoid switch contact.
Assuming the switch to be the problem, further delay in replacing the electrical portion of the switch will eventually add another symptom...... no start at all.
Frank
Re: 89 3,0L Starting Problem [Re: FrankR] #869282 02/21/08 04:53 PM
PatrickS Offline OP
I have removed the steering colum cover have found the rear unit but can see no screws or other way of removinng it. Have searced in the Forum for past posts and find nothing. What is the trick to removing the ignition?
Re: 89 3,0L Starting Problem [Re: PatrickS] #869283 02/22/08 02:34 AM
FrankR Offline
I've forgotten how the switch assembly is removed, but the rear white plastic portion is fastened onto the metal lock portion by two screws. IIRC, the entire assembly is captured by being sandwiched between the top and bottom column covers. Keep fiddling with it - it'll come out. Then you need to unplug the harness pigtail.
Frank
Re: 89 3,0L Starting Problem [Re: PatrickS] #869284 02/26/08 08:38 AM
PatrickS Offline OP
I am not sure but I might have found the problem. It starts with no problem for the last 5 days.
There was a second problem that led me to the first. Sometimes the heater fan did not start properly. I have traced the wires and found that the ground was not tight.
Along with the ground from the fan is a ground to the ECU. Cleaned and tightened them both and everything works for the last 5 days.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6428 MB (Peak: 0.7512 MB) Data Comp: Off Server Time: 2026-07-15 04:17:18 UTC
