Page 5 of 5 1 2 3 4 5
Re: 89 3,0L Starting Problem [Re: PatrickS] #869305 03/21/08 01:04 AM
FrankR Offline
Is it possible for the sensor to cause intermitant starting or running problems? They said I must replace distributor.
Yes..... this is why I explained the need to determine if you had "no spark" or no power to the coil.
It's now obvious you had "no spark". As I suggested, the distributor is a prime suspect and can certailnly cause the issues you are experiencing. The crank angle sensor is the optical sensor inside the distributor. It can be replaced - or you can install another used distributor..... but if you do, get a warranty on it.
Frank
Re: 89 3,0L Starting Problem [Re: FrankR] #869306 03/21/08 09:32 AM
PatrickS Offline OP
The options are limited here. The sensor is not available. Used are not available. Have sent it out to be rebuilt in Holland. Takes a week and costs about 300. If it fixes the problem then I can live with it. Thanks again.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: 89 3,0L Starting Problem [Re: PatrickS] #869307 03/21/08 11:40 AM
FrankR Offline
I suspect it will be fine with the rebuilt distributor.
Frank
Re: 89 3,0L Starting Problem [Re: FrankR] #869308 04/03/08 06:18 PM
PatrickS Offline OP
Frank
I have been driving it for 3 days no with no problems. It looks like it was the problem. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Why is it that the ECU did not show the fault code for so long when he problem has occured for weeks? Is it normal?
Thank You <img src="/forums/images/graemlins/patriot.gif" alt="" />
Patrick
Re: 89 3,0L Starting Problem [Re: PatrickS] #869309 04/04/08 12:36 AM
FrankR Offline
I don't know - for some reason, distributor codes seem to take a while to show up on the Gen1..... it's not the first time we've seen it.
It sounds like it's fixed. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6175 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-11-04 19:58:55 UTC
