Re: 89 3,0L Starting Problem
[Re: PatrickS]
#869305
03/21/08 01:04 AM
Is it possible for the sensor to cause intermitant starting or running problems? They said I must replace distributor. Yes..... this is why I explained the need to determine if you had "no spark" or no power to the coil. It's now obvious you had "no spark". As I suggested, the distributor is a prime suspect and can certailnly cause the issues you are experiencing. The crank angle sensor is the optical sensor inside the distributor. It can be replaced - or you can install another used distributor..... but if you do, get a warranty on it. Frank
[Re: FrankR]
#869306
03/21/08 09:32 AM
The options are limited here. The sensor is not available. Used are not available. Have sent it out to be rebuilt in Holland. Takes a week and costs about 300. If it fixes the problem then I can live with it. Thanks again.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
[Re: PatrickS]
#869307
03/21/08 11:40 AM
I suspect it will be fine with the rebuilt distributor.
Frank
[Re: FrankR]
#869308
04/03/08 06:18 PM
Frank I have been driving it for 3 days no with no problems. It looks like it was the problem. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Why is it that the ECU did not show the fault code for so long when he problem has occured for weeks? Is it normal? Thank You <img src="/forums/images/graemlins/patriot.gif" alt="" /> Patrick
[Re: PatrickS]
#869309
04/04/08 12:36 AM
Why is it that the ECU did not show the fault code for so long when he problem has occured for weeks? Is it normal? I don't know - for some reason, distributor codes seem to take a while to show up on the Gen1..... it's not the first time we've seen it. It sounds like it's fixed. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Frank
