89 3,0L Starting Problem Part 2 #869414 02/15/08 01:20 PM
PatrickS Offline OP
Starter works fine, new coil,distributor cap and rotor. Revsfor a second and then stops like the power was shut off.
When cold, turn key to start and there is power to coil for very short time and then stops. As the key is turned off there is power to the coil for another instant.
When I have luck and it starts and runs, after warms up, then is no problem to shut off and restart.
Removed the ECU, all conections appear in order and no leakage at the capacitors.
Just before the coil there is another very small module. Is this also a capacitor?
Any Ideas?
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: 89 3,0L Starting Problem Part 2 [Re: PatrickS] #869415 02/15/08 08:08 PM
No need to post this on a 2nd thread. I'd keep it all in one thread to avoid future confusion especially when you don't link this to the original thread. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 89 3,0L Starting Problem Part 2 [Re: off-roader] #869416 02/15/08 09:42 PM
PatrickS Offline OP
Thanks, I am not a profi here.
Am happy for all the help I can get.
This forum it great and I appreciate everything.
Re: 89 3,0L Starting Problem Part 2 [Re: PatrickS] #869417 02/16/08 12:57 AM
PHIL_ Offline
Copied your message into the first post. This one is now locked.
Hoepfully we can figure it out for you...
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5996 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-11-15 03:02:14 UTC
