Re: getting ready to swap 3.5 engine, what maintenance should I do? [Re: Mad_Scientist] #870087 02/20/08 03:58 PM
stony-man Offline
One thing about Advanced Auto & Auto zone alternators: You will get VERY good at replacing that part on your truck. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: getting ready to swap 3.5 engine, what maintenance should I do? [Re: stony-man] #870088 02/20/08 04:52 PM
monte Offline
I will say this if no one else has... <img src="/forums/images/graemlins/ignore.gif" alt="" />
Take off the plenum and every SINGLE one of those little butterfly valve "plates" and just put them back on with RED LOCTITE !!!
Otherwise, you're gonna be (I'd bet good money on it) sucking one of them in at a later time due to a few tiny, $ .10 bolts loosening on you <img src="/forums/images/graemlins/scared.gif" alt="" />
And then it's a head / valve job <img src="/forums/images/graemlins/zombie.gif" alt="" />
Jason
Re: getting ready to swap 3.5 engine, what maintenance should I do? [Re: monte] #870089 02/20/08 09:15 PM
ryany Offline
On that same subject, you should check to see if there's any play in the end of the variable intake butterfly shaft before you dive into your project. If there's any slop, the bushings that support the shaft are worn & you'll soon have a significant vacuum leak if there isn't one already. The movement in the shaft contributes to the butterfly plates coming loose. Plan on replacing your lower intake manifold if that shaft is moving at all.
95 Montero SR
Re: getting ready to swap 3.5 engine, what maintenance should I do? [Re: ryany] #870090 02/22/08 02:20 AM
E
exp500 Offline
Just from what I've seen so far- Change valve cover gaskets, spark plug tube seals, If valve cover areas are clean of oil residue no need to do cam/crank seals(look in filler neck), cut timing belt cover around crank so harmonic balancer removal not required next time.Lube all wiring connectors.Check plug boots, change wires. Remove butterflies- plug with 5/8 frost plug. Keep actuator in place for computer. Plug egr and add resistor.Wet and dry compression check.Good Luck
Re: getting ready to swap 3.5 engine, what maintenance should I do? [Re: exp500] #870091 02/22/08 06:43 AM
nedfunnell Offline
Since you're replacing the timing belt...
http://www.4x4wire.com/forums/showf...&sb=5&o=&fpart=1
<img src="/forums/images/graemlins/smile.gif" alt="" />
95 Montero SR - 207k miles, rebuilt @ 146k
Stock. Longview, Texas
Ithaca, NY for the summer of 08.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6143 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-06-20 19:06:01 UTC
