tranny swap
#870644
02/22/08 01:44 AM
89 ext 4x4 pickup 22re w56 140k
My w56 transmission started making some rattling noises on occassion, definately coming from inside the transmission housing. Oil level is full. Came across a pretty good deal for a transmission out of a 93 4x4 v6 model toyota pickup. Initially transmission looks pretty much the same except for the transfer case and cover underneath the shifter has 4 bolts to the transmission as opposed to a 6 bolt cover plate under the shifter of my w56. Is it possible to make this swap? Can i bolt up my gear driven transfer case to the v6 (r150 i think) tranny?
Re: tranny swap
[Re: mqm]
#870645
02/22/08 03:41 AM
Would likely require an R151 bellhousing (22RE turbo tranny) and an adapter plate for the t-case.
Re: tranny swap
[Re: 4Crawler]
#870646
02/22/08 04:47 PM
Is there a difference between the sline shafts of the w56, r151f and the r150??
Re: tranny swap
[Re: mqm]
#870647
03/01/08 03:22 AM
found a r151 tranny out of a turbo 22re 4x4. Will i have to modify anything to make this fit in place of my w56?
PHP: 7.4.33 Page Time: 2.191s Queries: 15 (0.008s) Memory: 0.6010 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-07-15 23:52:19 UTCValid HTML 5 and Valid CSS
