Likely gear ratio, 1997 4 cyl, auto? #870726 02/22/08 09:29 PM
Red_Chili Offline OP
Toyota Section Staffer
Yep, did a search. I *believe* it runs 4.10s, but before I go to the trouble of using some 4.56s I have laying about I thought I would ask.
I have looked up codes but there is some ambiguity depending on whose lookup table you use.
I can always jack up the rear and put it in neutral and spin, but 4.10 is pretty close to 4.56 and 4.30.
2.7L 4cyl., automatic Xtra Cab.
-Bill
Re: Likely gear ratio, 1997 4 cyl, auto? [Re: Red_Chili] #870727 02/23/08 07:29 PM
L
lawnmowerman Offline
It should be a 4.56 with an auto trans.If it was a 5spd it would be a 4.30.I had a 97 Reg Cab 4cyl Auto and it had 4.56.
Re: Likely gear ratio, 1997 4 cyl, auto? [Re: lawnmowerman] #870728 02/25/08 03:39 PM
Glad I asked! THAT would have been discouraging! <img src="/forums/images/graemlins/notooth.gif" alt="" />
-Bill
PHP: 7.4.33 Page Time: 2.915s Queries: 15 (0.008s) Memory: 0.5931 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-07-15 02:50:54 UTC
