A Sportage Heater core is simple to fix........ #871755 02/27/08 04:14 AM
Iron Offline OP
......when compared to that on a 64' Plymouth.
Took two weekends to get the b*****d thing out, involved removing the glove box, radio, 2 vacuum valves, 27 screws, a 7lb cast iron blower motor, and a 48"x12"x10" steel box with razor sharp rusty edges.
Then since you can't find a replacement core you have to get it re-cored, local shop quoted $500.00
And I still have to reassemble the heater box, motor, squeeze it back under the dash, and put everything back!
I'm looking forward to doing the one in the Sportage, I need a break! <img src="/forums/images/graemlins/nana.gif" alt="" />
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: A Sportage Heater core is simple to fix........ [Re: Iron] #871756 02/28/08 02:09 AM
LeadBelly Offline
I forget. Is a Sport Fury a B body or a C body? I have a NOS heater core that I bought years ago for a '66 New Yorker and never installed...
leadbelly
'99 Sportage 4dr EX 5-speed, unmolested
'98 Sportage 4dr Auto 2wd
'96 Sportage 4dr Auto,235-75x29"tires, custom fabbed hidden receiver hitch and big plans.
Re: A Sportage Heater core is simple to fix........ [Re: LeadBelly] #871757 02/28/08 02:19 AM
Iron Offline OP
64' was a B body, they changed in 65' The 66's heater is diffrent to the 64' if it is a NOS heater core you could get a few hundred $$ for it on ebay!
08' Jeep Wrangler
58' Triumph TR-3A
Re: A Sportage Heater core is simple to fix........ [Re: Iron] #871758 02/28/08 09:40 PM
Nukeiridium Offline
So far that doesn't sound any harder than the Sportage core, have you done the sportage one before?
When I did mine I had to strip everything off down to the firewall, like this:
On the other hand, I guess some people have done it a different way where you don't disassemble everything, instead you CUT the housing then glue it back together?
That sounds kinda like a half-*** job to me though... but whatever works!
Anyway I wouldn't look forward to the heater core job, it's not fun...
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: A Sportage Heater core is simple to fix........ [Re: Iron] #871759 02/29/08 03:57 AM
LeadBelly Offline
Maybe, after I posted last night I looked on Rockauto to see if the heater cores would interchange, and they're still available new there for the '66 C-body...I forget how much. (They don't list one for your'64)
Leadbelly
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6047 MB (Peak: 0.6693 MB) Data Comp: Off Server Time: 2026-10-22 11:24:10 UTC
