motor questions #871899 02/28/08 02:58 AM
skippy447 Offline OP
i just bought a "83 22R with 46,000km's on it that im planin on puttin in my truck in place of the old worn-out 20R. would it be worth gettin some head work done 2 the 20R head n puttin it on my 22R block? im runnin a top-load 4-speed, 4.38 gears, posi rear n 33" tires but thinkin bout upgradin 2 35"s. any suggestions would be great!
Re: motor questions [Re: skippy447] #871900 02/28/08 03:23 AM
Elbow_Greese Offline
If you're upping your tire size, the most effective upgrade you can do is regearing.
For 35's, I'd go with 5.29's.
It will bring your speedo back to near stock readings.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: motor questions [Re: skippy447] #871901 02/28/08 04:00 AM
missouriman Offline
NO..... 46,000 it is not even broken in. that is a great find. leave it alone.
Re: motor questions [Re: skippy447] #871902 02/28/08 09:47 AM
Snowtoy Offline
You can achieve some power gains w/the 20r head on the 22r, but wont likely see any of it w/33's(or 35's), and 4.30's. Your cheapest performance gain would be to swap a 5-spd for the 4-spd, then regear w/5.29's, so you can run 35's when the time comes.
Re: motor questions [Re: Snowtoy] #871903 02/28/08 05:11 PM
Kaptain Offline
Leave the engine alone and re-gear. You can get junkyard diffs with 4.88's fairly cheap if you shop around (car-parts.com).
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
PHP: 7.4.33 Page Time: 4.816s Queries: 15 (0.004s) Memory: 0.6043 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-06-24 08:19:22 UTC
