bending a pitman arm
#872695
03/01/08 08:01 PM
What do you guys think about bending a pitman flat? bad idea?
Re: bending a pitman arm
[Re: 95mini]
#872696
03/01/08 08:13 PM
You might comprimise the integrity of the metal by heating and bending. www.sky-manufacturing.com sells flat pitman arms
[Re: Adam F]
#872697
03/01/08 08:18 PM
I knew that I could purchase a flat arm, but I was just looking to save a few bucks.
[Re: 95mini]
#872698
03/01/08 09:47 PM
[Re: 95mini]
#872699
03/02/08 12:45 AM
Steering REALLY isnt a good place to save a few bucks.
[Re: 95mini]
#872700
03/02/08 01:12 AM
well first I have to ask why? it is alot better to set things up to work with off the shelf stock parts. I have the flat arm. but if I ever need a new one what will I do.. HOPE That sky is still around and making them. or set it up to work with stock.
just something to think about it.
[Re: missouriman]
#872701
03/02/08 02:33 AM
Why??
Here is a long winded answer. I started my SAS wanting to keep the truck fairly short and do it fairly inexpensively. So I decided to use rears up front. So I did the RUF, made slightly longer shackles for the rear and added a couple leafs, worked out pretty well except for the fact that my steering wasn't close to clearing. The truck has a 2" body lift on it and I can move the steering box far enough forward without touching the core support as long as I rotate it downward a little. The drop pitman doesn't give me much room for up travel with this setup. Personally I would rather have a non-stock pitman opposed to a cut up core support.
Can you picture how close everything fits up there without lifted springs or a drop hanger? Lucky for me I have a fork lift at work to flex it out and check everything. Which I have done with my bent pitman(had to be able to get the truck out of works garage and drive it a short distance home).
I'm close to taking the thing out for the first time since the swap and that bent pitman was a concern of mine, hence the question.
Thanks for the replies, I'll order one.
I hope to get some pics up in the next couple days. I've gotten a lot of good help on this forum. The least I could do is give you guys some pics <img src="/forums/images/graemlins/smile.gif" alt="" />
95 pickup, RUF, dual cases, 4.88s, detroit rear/lock-right front, high steer, and not stupid tall <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: 95mini]
#872702
03/02/08 02:53 AM
you asked, don't be defensive. I cut the core to where there was just a bit left there. it has been ok. of course I cut it up to add hydro assist. wife's, stock ![[Linked Image]](http://i115.photobucket.com/albums/n320/missouriman/3-2007%20toy%20rebuild/HPIM0535.jpg) mine ![[Linked Image]](http://i115.photobucket.com/albums/n320/missouriman/frame%20and%20bumper/DSC02323.jpg)
[Re: 95mini]
#872703
03/02/08 03:31 AM
I FULLY understand wheeling on the cheap. My truck is built from junkyard parts and mismatch stuff. But one thing I would never booty fab is the steering. Far too important. If that arm broke and you were on the highway you could kill yourself and others.
[Re: Adam F]
#872704
03/02/08 03:53 AM
I have a friend that has for years flattened pitman arms for the hotrod guys without a single failure to an arm. With that said, I went to him with my Toyota arm and asked if he could straighten it for me so it would work with my hy-steer. No problem as long as it is cooled right, he said. I ran that setup on some hard runs with no flaws. ymmv I am just saying the other side of the story. Danny
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
