Heater or thermostat? #872720 03/01/08 09:55 PM
Ghostrider Offline OP
87 22R. When the engine is above an idle the heater puts out hot air as it should. When I let it idle the air temp drops to the ambient air. I am thinking the thermostat is on the way out. Any other ideas?
Thanks
I live in the Great State of Confusion near the capital of Dementia
Re: Heater or thermostat? [Re: Ghostrider] #872721 03/01/08 10:23 PM
4Crawler Offline
Easy enough to pull out the t-stat and test is in a pot of hot water with a thermometer. Might be that it is too cold a unit and is letting the engine run too cold at idle.
Re: Heater or thermostat? [Re: Ghostrider] #872722 03/01/08 11:17 PM
wsquaredodie Offline
At idle your water pump is at idle too. If you are getting good heat at elevated rpm's the heater is probably ok as is the thermo. Make sure you have the fluid topped off. At idle, a little low is a little cool.
trafdlo
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5945 MB (Peak: 0.6475 MB) Data Comp: Off Server Time: 2026-06-07 01:22:37 UTC
