Vibrating noise. Need some expert advise.. #872758 03/02/08 12:58 AM
Stuart_Hemsley Offline OP
I have bought a 93YJ with 70,000 miles on the clock. The rear leaf springs are sagging and are shortly to be replaced.
I have found a really strange vibrating noise that is really loud around 40mph. As the speed of the vehicle inreases the tone gets louder.
It sounds similar to a worn wheel bearing, but we have changed them. Although the sound seems to come from the rear axle area its difficult to tell.
When bringing the vehicle to a halt the vibration is really bad like a vehicle with an overly agressive tire stud pattern on tarmac.
Has anybody had similar symptoms?
Can anyone offer a good way of being able to find the problem quickly, rather than spending time and money replacing parts that may not need it?
Sorry if my description is rather poor.
Re: Vibrating noise. Need some expert advise.. [Re: Stuart_Hemsley] #872759 03/02/08 04:03 AM
O
oldgreen Offline
Almost sounds like a bad or unbalanced tire. Try swapping the tires front to back to see if your vibration changes from the rear to the front.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: Vibrating noise. Need some expert advise.. [Re: Stuart_Hemsley] #872760 03/02/08 04:04 AM
BigJim Offline
TWO JACK STANDS AND RUN IT IN PLACE..
Damn caps key!!
Re: Vibrating noise. Need some expert advise.. [Re: BigJim] #872761 03/02/08 11:37 AM
PartyTruck Offline
Check the joints on the rear propshaft. If they are greaseable then give them a couple of squirts of grease and check if the symptoms change. I have had a similar problem twice before and one was worn out U-joints and the other was a totaled draglink.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5989 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-10-24 22:02:10 UTC
