Re: Better gas mileage. help
[Re: eleet]
#873183
03/23/08 05:10 PM
anyone ever used a universal intake kit- just built their own instead of payin ~$250??
[Re: T100_4x4]
#873184
03/26/08 02:31 AM
I've run K&N filters, as well some oiled foam filters off and on over the years in various applications. I've never found the intake or the piston on the CV carburetors to be oily or oily/dirty as a result. I find it highly suspect to think that K&N oil only travels onto the wire of the air mass meter. Not that I do not think oil comes off, especially when initially installed with excess oil. But I don't find oil soaked intakes and such.
'97 T-100 SR5 '86 Toyota's, the variety pack (all gone)
[Re: T100_4x4]
#873185
03/26/08 11:26 AM
Did you make any changes to increase yer MPG yet?
[Re: T100_4x4]
#873186
03/30/08 04:27 PM
anyone have a body lift on their T and also have a K&N intake installed??
[Re: toyT100]
#873187
03/31/08 02:59 AM
well i did my psi in my tires, cleaned my throttlebody and intake and everything with brake clean, got out a bunch of dirt and oil from when my spark plug came out and blew my valve cover gasket. my next step is going to be replace the air filter. Im still getting about 15mpg average for a tank of gas and wondering how come everyone else is getting 17-20 mpg. my old man is a mechanic and he was saying that with the obd2 (i think it was ) with all the computer controled dyonostics if an o2 sensor was bad the check engine light would come on for sure. I dont have any muffler or exhaust after my cat, i took it all off. so basically it goes from my headers to my cat and ends there. I do fill up at arco and am wondering if that may be why my mileage sucks so much.
[Re: T100_4x4]
#873188
03/31/08 03:17 AM
What size tires do you run?
J-Bird
'95.5 T, SR5, Bone stock w/32x11.50's '06 Sonata LX
[Re: T100_4x4]
#873189
03/31/08 03:19 AM
Run some seafoam through it...about $6 can. You can git it at AutoZone, Advance, Checkers, Walmart... Follow the instructions carefully... <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6230 MB (Peak: 0.7132 MB) Data Comp: Off Server Time: 2026-06-05 05:57:52 UTCValid HTML 5 and Valid CSS
