Help with the GF's car #874018 03/08/08 11:32 PM
stock87 Offline OP
2003 Hyundai Accent, about 70k miles I think.
When going around sweeping right hand bends, the car can start to oscillate rather badly from side to side. Sometimes it's pretty minor, sometimes it's pretty bad. Tires are good, shocks aren't great, but it only does it going right.
Any obvious places to start looking?
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Help with the GF's car [Re: stock87] #874019 03/08/08 11:55 PM
JAVYPRO Offline
Jack it up and by grabing the tire wiggle it to see if it moves, you might need bearings.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Help with the GF's car [Re: stock87] #874020 03/08/08 11:56 PM
Bogo Offline
Yes. To me it sounds like something is to loose and goes into oscillation while cornering.
I'd look at all the linkages in the front suspension including the steering links. Check for looseness and or breakage. Also look the ball joints. You will need to jack the car up and possibly remove the tire for some of these checks. When you try to wiggle things, put some muscle into it. After all the car's whole weight is on these components.
Not knowing the specific car's design, I'd bet it has a trailing arm rear suspension. I'd check the linkages used to keep the arms straight, and the condition of the arm it's self. I had one on a Chevy Nova go bad so the arm flexed more than it should. As such it effected the handling.
-- Bryan
Re: Help with the GF's car [Re: Bogo] #874021 03/09/08 02:15 AM
stock87 Offline OP
Bingo. LR wheel had side to side play when it was jacked up. Found a loose bolt and tightened it. No more death wobble!
Re: Help with the GF's car [Re: stock87] #874022 03/09/08 04:52 AM
LRJ4x4 Offline
thats scary <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Help with the GF's car [Re: LRJ4x4] #874023 03/10/08 06:47 AM
stock87 Offline OP
And today rotating the tires, one of the lug studs stripped and spun, resulting in my having to break it off with a 5lb sledge hammer just to get the wheel off. The Koreans still don't quite have it...
Re: Help with the GF's car [Re: stock87] #874024 03/11/08 03:53 AM
That's a sign of improper impact wrenchin' at the last tire store...
Re: Help with the GF's car [Re: fasteddy] #874025 03/11/08 04:06 PM
Bogo Offline
Also cheap lug bolts. I now put a drop or two of oil onto the threads before installing any lug bolt. Likely should use an anti-seize compound instead. I've had to put 6' pipes on 3/4" breaker bars to remove some lug nuts put on by a tire shop but the lug bolts held up to it. A car's should handle at least a 4' pipe.
-- Bryan
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6241 MB (Peak: 0.7233 MB) Data Comp: Off Server Time: 2026-07-16 14:34:55 UTC
