I already have the D300 & kinda like them. We will see.
This is fine, but you will have to buy an adapter, and that adds length, and price.
The 4l60 came in the car & I do have the ECM with underhood & under dash harnesses, along with the column. It's all OBD I.
Car 4L60? If so plan on a complete teardown to swap the tail shaft. Must be a 93/4/5 if it is an OBD1 4L
I was thinking about getting CATS or one of the other editing programs. I am already pretty versed in Tunercat.
Yep. Tunercat, and an LM1 will get youi all srt up, but if you leave it stock, just stick the old ecm in there, and call it good.
I have researched cams & you are right about the hotcam. There are some milder ones that are suggested for the engine. Or, I might just leave it stock w/ flowing intake & exhaust & some tuning.
GOOD plan. Glad you came to your senses on that one.
When I get it all, I need to measure it all for DS length. I am thinking about a rad in front of the support.
Get the drivetrain installed, and then measure for driveshafts. The radiator will have to move foward, and so will the condensor. All a PITA to re-set up.
Also have to figure PS pump pressures, A/C compatibility, aftermarket fuel pump, mounts, wiring ( easiest for me) & reprogramming.
PS pump pressures. Can't help you. My mitsu pump was angry with my GM pump. My solution was to ditch the mitsu steering setup completly.
Fuel pump is easy. External on the floor of the truck above the tank. Mounts are DIY also. Flatbar, and round stock, or modify factory Gm mounts. Wiring... Thats as big of a monster as you make it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
