Page 1 of 3 1 2 3
manifold nuts #874530 03/11/08 12:48 AM
cjsmontero Offline OP
Can I use aftermaket nuts on the manifolds...intake and exhaust? With lock washers? I know there one use mitsu nuts, but I need em quick and dont have a mitsu dealer close.
cjm <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: manifold nuts [Re: cjsmontero] #874531 03/11/08 01:28 AM
FrankR Offline
Yes, but note that the OE exhaust manifold nuts are bronze or some other copper alloy.... useful to eliminate rust that always rears its ugly head when it's time to remove exhaust fasteners.
Frank
Re: manifold nuts [Re: cjsmontero] #874532 03/11/08 02:05 AM
Thanks!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: manifold nuts [Re: cjsmontero] #874533 03/11/08 02:39 AM
Nuts with spiral lock washers won't stay tight. The lock washers lose temper and tension when heat cycled. Loctite won't work, either. I've donated several nuts to the road that way. Might work for a week until you get the real thing, and might not. My best "other source" solution was to use flat washers, loctite, and flange nuts with serrations on the flange.
Re: manifold nuts [Re: cjsmontero] #874534 03/11/08 05:23 AM
Ace Hardware also sells metric crimp nuts.
Re: manifold nuts [Re: rxinhed] #874535 03/11/08 05:41 AM
LandRaider Offline
The BEST solution is to Safety wire.
Thats what I'm gonna do on my Chevelle when I have stainless 2.25 inch primary headers, and a Big ole T-4 sitting on top of each bank. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: manifold nuts [Re: LandRaider] #874536 03/11/08 06:52 AM
mxmikie Offline
if you put cherry mylanta on the studs before you install the new nuts they will stay tight until you need to remove them the mylanta works like lock tight
Re: manifold nuts [Re: mxmikie] #874537 03/11/08 08:14 AM
LandRaider Offline
uhhhhh ok. why not just use locktight? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: manifold nuts [Re: LandRaider] #874538 03/11/08 11:31 AM
Y
yankneck696 Offline
TT Chevelle? Sounds nice. I work on a collection of 200 GM muscle cars & there are 23 Chevelles. Gonna be a museum in 6 months or so.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: manifold nuts [Re: yankneck696] #874539 03/11/08 08:27 PM
LandRaider Offline
Yeah. I have a 79, and Tag has a 70 I think.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6383 MB (Peak: 0.7468 MB) Data Comp: Off Server Time: 2026-11-03 07:08:48 UTC
