exhaust #875176 03/14/08 03:30 PM
thunder72 Offline OP
I am looking for some new exhaust. I think I'll go with headers and all new cat back system has anyone got any good ideas. And how much power is to be gained and clearance are the main factors. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: exhaust [Re: thunder72] #875177 03/14/08 04:05 PM
BigJim Offline
What you will get is lots of noise that will confuse your senses and make you THINK you have more power. But if there IS more HP it will be at high rpm where the lil Jeep engine fears to tread.
In order to get more exhaust OUT one must first allow more gas INTO the engine. So unless one does an expensive HEAD JOB and intake system and then intends to run at much higher rpm, the fancy exhaust will be of no use to the Jeep. Dual exhausts actually HURT low rpms, as the scavenge effect of the pipes doesn't start working until a certain velocity is achieved.
Re: exhaust [Re: thunder72] #875178 03/14/08 11:07 PM
W
WB6TMV Offline
Gotta agree with Jim on this one. As a long time motorcycle builder/rider/tuner you have to look at this as a system, not just a single component. Can't tell you the number of times people have come to me with the question, " I just installed a new (insert here - exhaust, header, air intake, cam, etc.) and I see no big difference..." So, the following bit of advice.
While you may start with headers and an exhaust system, the reality is that until you also address the intake system limitations, the fuel mixture (as the air volume will change and may involve remapping the ignition system)you will not realize the value of the investment. And, the parts have to be selected to work together, not just a random purchase of parts. Remember what goes in must come out. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Richard - 08 JK, 2.5" OME lift, nitrocharged shocks, Rugged Ridge front bumper with M8000 winch, JKS QDs - Olympic 221 rock sliders and rear rock crawler bumper, upper adj control arms f/r, JKS adj track bars f/r
PHP: 7.4.33 Page Time: 2.163s Queries: 15 (0.009s) Memory: 0.5924 MB (Peak: 0.6457 MB) Data Comp: Off Server Time: 2026-11-04 14:27:48 UTC
