Re: Jeep Cherokee [Re: BigJim] #875417 03/17/08 04:18 AM
cuervo25 Offline
o2 sensor it sounds like to me, have it tested. Mine done the same thing a few years back until i hooked it to a scanner and founed it wasn't going into the proper loop.
Re: Jeep Cherokee [Re: cuervo25] #875418 03/17/08 11:31 AM
E
el_d_m Offline
after you change that coil make sure your plug wires arent trading voltage. check your vacuum lines especially on that dang map sensor on the firewall.
by the way what year is she & what engine? how many miles on her.
i wonder if the crank sensor vibrated loose or got bumped. mine did that when some brush hit it.& my girl died right there the motor did all sorts of funky timing stuff.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5933 MB (Peak: 0.6414 MB) Data Comp: Off Server Time: 2026-06-07 02:18:52 UTC
