Page 2 of 3 1 2 3
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: reknawj] #875493 03/16/08 09:45 PM
LandRaider Offline
Have you seen the thing? It looks like a damn figure 8! The air won't go straight down, well it will but not before passing two separate intake passages. I'm no expert but I can't help but think that all of the resulting turbulence would be a negative. All I have to do is look at the design of simpler intakes.
Really sounds like you should do some research on intake and plenum design.
Generally Speaking:
* Longer intake passages produce more low end torque. The 3.5 runners are no doubt engineered to specifically match the intake pulses. Similar to a Tuned Port GM intake manifold. High end Hp is sacraficed to provide low rpm torque. Good for passenger cars and trucks that are heavy, or need to get a load moving.
* Shorter intake runners produce more high end HP by reducing turbulance, and increasing flow. ie a single plane manifold in a carb application, or individual throttle bodys on an EFI spp..... basically race car stuff that needs super high end HP, and can sacrafice all the low end torque.
Whoever designed that intake system was an engineer, and did not put anything in there they thought would decrease performance, be it HP, Torque, Noise.... I'm not an engineer either, so I usually try to make small changes, and do a crap ton of research to find out how I am changing the whole picture.
I will go look around, and find you some Intake research stuff, and you can go from there.
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: LandRaider] #875494 03/16/08 09:55 PM
LandRaider Offline
IF IT WERE ME, I would Rebuild the butterfly shaft with Nylon inserts, or another suitable material, and leave it alone.
IF I could not stand the butterflys any more, and thought I coudl get away with removing them(many folks have) then I would pull them, and the shaft, and tig the shaft holes up, and smooth the welds out on the inside. Hopefully someone here who has done that will chime in with some pictures.
Here are some links for you. Not specifically to intake tuning, but...
http://www.phys.unsw.edu.au/jw/Helmholtz.html
more when I get a chance.
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: LandRaider] #875495 03/16/08 10:11 PM
reknawj Offline OP
The biggest issue out of all of this is the fact that the part replacement is about 350 bucks. I would love to simply purchase the replacement and utilize the design the engineers intended. (I can't, no loot!) That said, I appreciate your input. I just don't want to slap the old one back on without the butterfly assembly to divert the flow as designed. Maybe the turbulence is the best compromise. The only Monty vehicles to utilize this design are 94-97 SR's so maybe the three year stint is a sign that it was flawed. Again, the proper solution is not a doable solution!(for me)
1994 Montero SR
Divide Colorado
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: LandRaider] #875496 03/16/08 10:12 PM
LandRaider Offline
SO pull the shaft, and tig up the holes.
http://www.rbracing-rsr.com/runnertorquecalc.html
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: LandRaider] #875497 03/16/08 10:31 PM
reknawj Offline OP
PM me your email and I'll send you a diagram of the plenum. you'll be able to see all the weird bends and holes.
I am perfectly aware that I can plug the holes and move on. It's just that I found some used intakes from newer montero's and 3000GT's for around $40 and figured "hey I can just grab one of those, throw it on and have no turbulence...alright!! sweet!!" ... It sounds like the GT won't work, but what about a '98 3.5 or even 3.8??
1994 Montero SR
Divide Colorado
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: reknawj] #875498 03/16/08 10:51 PM
87Montero Offline
I PMed you back, dude
Brendan
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: 87Montero] #875499 03/16/08 11:28 PM
reknawj Offline OP
Thanks Man, got it!
1994 Montero SR
Divide Colorado
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: reknawj] #875500 03/17/08 12:58 AM
LandRaider Offline
I see your picture.
How would there be more air turbulance after you removed the butterflys as opposed to when it is functioning normally, and the butterflys were open?
When it is closed, the intake passages are longer, and provide the low end torque, and when it is open, it's tuned for more power at a higher RPM. Very cool I think. Apparently you need to build the bushings for those butterflys out of a quality material or they will kill your motor upon ingestion.
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: LandRaider] #875501 03/17/08 01:15 AM
FrankR Offline
The long butterfly runner ideas were first designed by Porsche engineers and found to actually provide a positive intake pressure that increased cylinder filling. Fiat also used them.
Turbulence is sometimes a good thing - particularly in an intake tract at the point where fuel injection and subsequent utility are concerned:
Effect of Turbulence in Intake Port of Mpi Engine on Fuel Transport Phenomena and Nonuniformity of Fuel/Air Mixing in Cylinder
Document Number: 900162
Date Published: February 1990
Author(s):
Jun Takemura - Mitsubishi Motors Corp.
Daisuke Sanbayashi - Mitsubishi Motors Corp.
Hiromitsu Ando - Mitsubishi Motors Corp.
Abstract:
Three zone mixture preparation model, assuming that fuel and air are distributed in three separate zones, fuel air and mixture zone, was proposed. Air Utilization Efficiency derived from the model was used to evaluate the mixing nonuniformity.
Effect of the large scale nonisotropic turbulence downstream of the dimple or edge in the intake port of MPI engine on the convective mass transfer from fuel film was clarified by the proposed nondimensional index, Local Sherwood Number. It was found that when the fuel is injected toward the wall where large scale turbulence exists, almost all of the fuel is seeded in the air passing the region at the beginning of the intake process, resulting in the time-resolved nonuniformity of the mixture strength at the intake valve.
Using the Air Utilization Efficiency, it was elucidated that time- resolved mixing nonuniformity at intake valves induces spatially nonuniform fuel/air distribution in the cylinder.
If you want to pay the price for a download, the entire technical paper can be obtained here:
SAE International
Frank
Re: 3000gt intake compatible with monty 3.5 to eliminate butterfly issue [Re: FrankR] #875502 03/17/08 02:43 AM
You have to think in waves of energy, and flow in cfm. The way I see it, you at worst have two converging flows without the butterflies. Each of these will be at a lower velocity than the originals, but total volume may actually go up. You could also get some extra turbulence from the converging flows.
Now look at the helmholtz waves. The runners are different lengths to tune the helmholtz effect at two different rpm ranges. Long runners for low rpms, short ones for high rpms. The reason for this is that the helmholtz waves propogate thru the air in the runners at a constant speed. In the intake, when the valve opens, it creates a region of negative relative pressure that propogates thru the air medium at the speed of sound. When the vac wave hits the end of the runner tube(s), it reflects back down the tube, but as a pressure wave instead of a vac wave. If the runner length is tuned so that the returning pressure wave hits when the valve is still open, it shoves some more air into the cylinder than just the runner flow would allow. This pressure can approach 10psi. Now you have two sets of waves. One set hits at the right time. The other set hits wrong, at least at that rpm. The waves may also be slightly weaker from being split into two runners. Dunno.
All that said, I don't think that any power loss is worth even hacking a $40 JY manifold to try to get it back.
Just turbo the damn thing and quit having to worry about Helmholtz effects to fill the cylinders...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6531 MB (Peak: 0.7603 MB) Data Comp: Off Server Time: 2026-06-09 21:43:32 UTC
