Re: Stripped Spark Plug Threads, HELP! [Re: wsquaredodie] #875581 03/18/08 11:53 AM
ttreat Offline OP
Thanks for all the suggestions. I ended up re-tapping and using an insert.
I tried a pipe wrench on the tube but it wouldn't budge. I imagine I could eventually of got it out but I would have destroyed the tube in doing so.
Let me offer a suggestion, check your plugs for tightness regularly. The plug was not cross threaded. It loosened after being in for about 2 years. The plug loosened enough that the last threads could no longer hold it in the head and blew it out. When it blew out, it stripped the last threads and also broke the coil.
ttreat
95 T-100 SR5 4x4
Pretty much stock, except for the goofy oil pressure gauge the previous owner installed.
Re: Stripped Spark Plug Threads, HELP! [Re: wsquaredodie] #875582 03/18/08 06:55 PM
T100_4x4 Offline
go to napa and get a spark plug threading tool, i did this on my truck and it hasnt been a problem since. tape the tool to a socket and make sure you dont mess up.
Re: Stripped Spark Plug Threads, HELP! [Re: T100_4x4] #875583 03/19/08 03:32 PM
ErikB Offline
Toyota Moderator
Another tip:
Use anti-seize compound on the threads to help keep them from getting galled/stripped, etc. too.
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5996 MB (Peak: 0.6527 MB) Data Comp: Off Server Time: 2026-06-19 04:01:46 UTC
