Page 2 of 5 1 2 3 4 5
Re: What I've been up to... [Re: NathanC] #875689 03/18/08 05:56 AM
ES_97Sport Offline
My only question is WHY would you want to use the stock t-case?!? Not that it's a POS or anything, but wouldn't it be easier - not to mention cheaper - to use twin 231s? Even at stock 2.72*2 the gearing is tons better - especially relevant if you're building a crawler out of it.
I'm just using it for the doubler. It won't be as nice as dual NP231s as far as the 2.72 x 2.72 reduction, but, it will still be 1.9 x 2.72 and that's better than a kick in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />.
Using the Mitsu case as the doubler also keeps the tranny shifter in it's original configuration, which I felt was a plus.
DANG Nathan!!!! THAT is SHARP!!! Jealous!!! I take back all the bad things I've ever said about you! You DO rock! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Hmm. Makes sense. Keep us posted on how that goes with the stock t-case. Yea, can't argue with that - 1.92x2.72 IS DEFINITELY better then a kick in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />! <img src="/forums/images/graemlins/smile.gif" alt="" />
We're done to the adapter shaft. Need to find a length of 4340 or some such now. Still no pics. Forgot the dang camera this morning.
Re: What I've been up to...(pics added) [Re: NathanC] #875690 03/18/08 09:28 PM
I like the way Nathan is approaching the transfer. By using the Mits reduction for the front eliminates much fabrication time and has him to one custom spline set and adapter. If more reduction is desired it can be done in the rear 231.
I am using a 231 in the center and a stock SR transfer in the rear, for mine this is more appropriate since I am using a 6 speed manual so an adapter is needed anyways and I place a greater emphasis on road use so I am retaining the AWD feature.
Re: What I've been up to...(pics added) [Re: OldColt] #875691 03/24/08 11:18 PM
ES_97Sport Offline
I like Nathan's approach, too, and it's certinly eliminates the need for the adapter from the trans to the t-case and the required 'spud' shaft. So far the adapter hasn't been much of an issue but finding 4340 heat treated in less than a 12' section is turning into a real pain in the rear. <img src="/forums/images/graemlins/frown.gif" alt="" /> Gonna end up at McMaster-Carr and then have it heat treated here in Denver, I suspect. <img src="/forums/images/graemlins/frown.gif" alt="" />
I think if I wanted to retain AWD, though, I'd stick with the NP231 in the front and put a NP241 in the rear.
But, that's where Nathan and I differ in approaches. I'm trying to get RID of anything Mitsu manual transmission related - including eventually the transmission. Nathan is trying to retain as much of the factory Mitsu design and parts as is reasonably possible.
Both of the approaches are fine. But the drive behind mine is that I put 40,000 (abusive) miles on a year and I can't have my Sport down for repairs for even a week without dissrupting my business. (it's going to be hard enough to go down for the couple days it'll take to swap t-cases next month) That means that I have to be able to get parts ASAP and they need to be cheap and repairs have to be quick and as relativly painless as possible. Example: I can rebuild an NP231 (now) in probably not more than an hour and the rebuild kit is less than a couple hundred dollars and it's available from everywhere. It takes at least an hour to tear down a Mitsu t-case, you have to have a couple specialty tools and I KNOW the rebuild parts are a LOT more expensive than $200! <img src="/forums/images/graemlins/scared.gif" alt="" />
If I were just building a crawler and was driving something else for work, etc. I'd do it Nathan's way. Cheaper and if you check the PDF on my site - Nathan's setup is a LOT less complicated! Definitely an easier approach from what I've read of his posts. <img src="/forums/images/graemlins/kewl.gif" alt="" />
But, if you're shooting for long term simple and cheap maintenance the dual NP231 setup is it. And, you'll get (slightly) better gas milliage from the NP231 - less rotating internals. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: What I've been up to...(pics added) [Re: ES_97Sport] #875692 03/24/08 11:52 PM
Why are you keeping the stock five speed then if you dislike them so much.
Re: What I've been up to...(pics added) [Re: OldColt] #875693 03/25/08 12:13 AM
ES_97Sport Offline
Its not so much that I dislike the 5-speed. I'm just not interested in trying to maintain a piece of equipment that Mitsu obviously isn't going to support long term.
AND, if I had the time and $$$ I WOULD have swapped the Mitsu 5-speed out for the Richmond 6-speed at the same time as doing the t-cases. But, ... <img src="/forums/images/graemlins/frown.gif" alt="" /> Next year! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: What I've been up to...(pics added) [Re: ES_97Sport] #875694 03/25/08 01:47 AM
There are many 6 speeds that are much easier to swap in than a Richmond.
Re: What I've been up to...(pics added) [Re: ES_97Sport] #875695 03/25/08 01:58 AM
NathanC Offline OP
LOL, I was just logging on to give an update for the day, and I find the thread has been bumped for me. <img src="/forums/images/graemlins/smile.gif" alt="" />
I finished up the rear cab mounts tonight. They had to be moved rearward and out. I used solid plate to space them outward. The cab is now solidly bolted to the frame in all six locations. I might be able to raise the fuel tank an inch or two for extra clearance.
I also decided to start checking out some of the other stuff. I hooked up the steering shaft, which was a direct swap. I also dropped the engine and transmission in place. The SOHC 3.0 is a much tighter fit than the 2.6 was (duh <img src="/forums/images/graemlins/lol.gif" alt="" />). At one point I started to get concerned that I might have mis-measured. A body lift might be required to clear the hood.
It looks like the shifter hole is almost perfectly located too. If I'm lucky, I'll be able to use the original center console with little to no modifications. That is, other than an extra shifter somewhere. <img src="/forums/images/graemlins/wink.gif" alt="" />
I haven't made much progress with the doubler t-case. I think I have the adapter plate pretty much done. I still need to complete the shifter. I think I might get a bit more complicated and try to re-use one of the position switches so I can detect if it is in low or not.
I was planning on SAS this while I was at it, but I might have to push that off for a bit. I need to move in June and I need to start saving up more cash to do so. <img src="/forums/images/graemlins/baby.gif" alt="" /> Worse case, I should still be able to wheel it with IFS. <img src="/forums/images/graemlins/shiner.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: What I've been up to...(pics added) [Re: NathanC] #875696 03/25/08 02:05 AM
Sounds like great progress. What are your thoughts about the bed at this point?
PS,We will try to keep your thread up top for you.
Re: What I've been up to...(pics added) [Re: OldColt] #875697 03/25/08 02:13 AM
NathanC Offline OP
LOL, OK, sounds good to me. I'm glad you guys are keeping it related to the original topic. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I'm not sure about the bed yet. I roughly measured the other night and it looks like an easy 8" needs to be removed between the cab and wheelwell. Removing some overhang on the rear sounds pretty tempting too. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
I really haven't ruled anything out. I have three main options in my head:
1)some sort of custom flatbed
2)bobbing the original bed
3)use the original bed sides as a plug and make a fiberglass mold
I'm giving myself all the time that I can to think it over. <img src="/forums/images/graemlins/baby.gif" alt="" />
'88 Mighty Max
Re: What I've been up to...(pics added) [Re: NathanC] #875698 03/25/08 02:27 AM
FrankR Offline
That would be just the right size for a real nice custom multi-unit bird dog box...... 2-4 dogs would feel right at home. The rear cab space is great for gun/ammo storage.
It'd make a terrific hunting/fishing truck if the dog boxes could be removed and swapped for a big cooler, bar and cooking rig.
I like it a lot! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.6580 MB (Peak: 0.7680 MB) Data Comp: Off Server Time: 2026-11-17 06:07:50 UTC
