Page 1 of 5 1 2 3 4 5
What I've been up to... #875679 03/17/08 12:33 AM
NathanC Offline OP
Building the thing that should not be. <img src="/forums/images/graemlins/scared.gif" alt="" />
It started with the 88 Mighty Max that I aquired late last year. Originally I intended to make a fun driver out of it, and even adapted a KM148 tailhousing to mate to an Active Trac t-case. For some reason, I let my twisted imagination roam and decided to make an all-out wheeler with it instead.
A month or two ago, I picked up a Montero Sport chassis w/ a 3.0 and V5MT1 transmission. Some quick measurements made me realize that the Montero Sports and pickups really do share many features. The first and second pair of cab mounts are located in exactly the same spots as the Mighty Maxes.
Today, with help from DougB and my brother (thanks guys! <img src="/forums/images/graemlins/cheers.gif" alt="" />), we transfered the cab from the Mighty Max over to the MS frame. I removed the third pair of cab mounts and still need to relocate them to the proper position roughly 3" rearward. It's amazing how well the cab fit the chassis, even the fuel tank was notched just right to perfectly clear the MacroCab! <img src="/forums/images/graemlins/cyclops.gif" alt="" />
I decided to use the MS chassis because it is in better shape, has the V5MT1, and has a much better wheel base.
The dual t-cases in the SR have really spoiled me, however, so I've been working on a dual transfer case setup for the V5MT1. It has proved to be a real challenge, and it's not done yet. I am using the original t-case as the doubler which has required a custom shaft as well as an adapter plate. I'm roughly half-done with the adapter plate and the shaft is completed. With this setup, the transmission and doubler t-case shifters will be in the original locations. I will need to add another shifter for the rear t-case.
I am making the adapter plate with a clocking ring that will mate to the Jeep round six bolt pattern. I plan to use the rear NP231 that is currently in my SR for the rear case on the Max. I still need to modify the doubler shifter rail and get it functional.
I also plan to ditch the IFS and SAS w/ a HPD44. I've been trying to aquire a parts SR and if it works out, I'll try to use the big rear axle w/4.90 gears and possibly use the 3.5 as well.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: What I've been up to... [Re: NathanC] #875680 03/17/08 01:36 AM
sparkem Offline
Sounds awesome, we demand pics. What are you going to do with the bed area? Flat bed?
87 (I think) 2wd Toyota PU on 93 4Runner chassis. The gauges worked, the front body mounts fit perfect, the rear needed to be moved. Awesome truck, got flooded and someone stole the rims and tires.
Re: What I've been up to... [Re: sparkem] #875681 03/17/08 03:58 AM
NathanC Offline OP
Not yet sure what I'm doing with the bed. I'm focusing on other areas of the truck to give myself time to think about it. <img src="/forums/images/graemlins/wink.gif" alt="" />
I'll try to get some pics. I didn't want to take any today because the garage was a mess from the work I've done (and haven't done <img src="/forums/images/graemlins/baby.gif" alt="" /> ) lately.
'88 Mighty Max
Re: What I've been up to... [Re: NathanC] #875682 03/17/08 07:35 AM
ES_97Sport Offline
SWEET!!!! I agree with sparkem. Must post pics!!!
I knew about the - more than passing - similarities from the Sport and Max. Figured that out within a year of owning my Sport.
My only question is WHY would you want to use the stock t-case?!? Not that it's a POS or anything, but wouldn't it be easier - not to mention cheaper - to use twin 231s? Even at stock 2.72*2 the gearing is tons better - especially relevant if you're building a crawler out of it.
Unfortunately, I don't have a CAD drawing of the adapter we're working on. But so far it consists of two T6 3/4 plates on either end of a T6 5" long 6"x.5" section of pipe with a 1" plate on top to mount the transmission shifter using the stock mount plate. The whole adapter has turned out to be a LOT less complicated than I'd previously thought it'd be.
Still this is totally cool!!!! Can't wait for more details!
Re: What I've been up to... [Re: ES_97Sport] #875683 03/17/08 11:16 AM
NathanC Offline OP
I'm just using it for the doubler. It won't be as nice as dual NP231s as far as the 2.72 x 2.72 reduction, but, it will still be 1.9 x 2.72 and that's better than a kick in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />.
Using the Mitsu case as the doubler also keeps the tranny shifter in it's original configuration, which I felt was a plus.
'88 Mighty Max
Re: What I've been up to... [Re: NathanC] #875684 03/17/08 05:57 PM
i always wanted to buy a cheap '00+ sport and import a strada l200 body for it, i think it would be awesome to have a pickup with coils in the rear. i love that bodystyle[Linked Image]
Re: What I've been up to...(pics added) [Re: NathanC] #875685 03/17/08 11:28 PM
NathanC Offline OP
Ignore the 2x4's. They are there for lifting points. <img src="/forums/images/graemlins/notooth.gif" alt="" />
'88 Mighty Max
Re: What I've been up to...(pics added) [Re: NathanC] #875686 03/18/08 12:20 AM
sparkem Offline
My bro has a rolled 95SR, Hmmmm.
Re: What I've been up to...(pics added) [Re: NathanC] #875687 03/18/08 01:47 AM
Looking nice Nathan <img src="/forums/images/graemlins/cheers.gif" alt="" />
I cant wait till I can get going on mine, another month our snow will be melting away and I can get my parts together.
Re: What I've been up to...(pics added) [Re: sparkem] #875688 03/18/08 02:54 AM
NathanC Offline OP
Realize that the Montero has the engine placed further back than the MS and trucks. It could certainly be made to work, however. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks Charlie, I'm sure yours will be quite the build. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Mighty Max
PHP: 7.4.33 Page Time: 0.040s Queries: 15 (0.033s) Memory: 0.6457 MB (Peak: 0.7728 MB) Data Comp: Off Server Time: 2026-11-16 10:30:02 UTC
