Anybody ever heard of this? #876229 03/19/08 04:31 PM
duece Offline OP
I just recently did some work on my 92' Toyota and have a weird problem going on and need some ideas. One of the things I did was put new plugs and plug wires in it. About a month ago, it was missing real bad and I went out at night and cranked it up, and lo and behold it looked like a Walt Disney fireworks show going on under my hood. So I replaced all the plugs and bought new wires and replaced them as well. I also replaced the breather tube that goes from the intake to the air filter as it had a large hole in it that wasn't helping things. Viola! The truck was running the best it had since I'd bought it back in 98'! About a week a go, I noticed it missing again, this time only slightly, but a definite miss. Now, it is missing quite a bit again. I cranked it up in the dark again last night and sure enough, I've got 1 plug wire that's just glowing?! Can plug wires go bad that quick? I didn't get bargain basement one's but I also didn't get real expensive either. Has anyone ever seen this? Is there something I did wrong when installing them?
Thanks,
Duece
"When you're dumb...you've gotta be tough!"
81' Jeep CJ5 31x15.50 Ditch Witch Tractor tires 8500lb winch dog box; 92' Toyota p/u 3.0 v-6 auto tranny, 31x12.5 Super Swamper Bogger's, JVC CD player 8" Bazooka Bass tube, Clarion mids and highs.
Re: Anybody ever heard of this? [Re: duece] #876230 03/19/08 07:35 PM
suba Offline
Is the arc happening near the plug itself, or near the distributor at all? Its always possible that the cap has a crack in it or something like that. I've had several that were cracked and I couldn't see it until I had it off the truck.
86 4runner, pro comp AAL, Kayline Soft top, 31's but all stock
Re: Anybody ever heard of this? [Re: duece] #876231 03/24/08 10:36 PM
Cochip Offline
Check the routing of the plug wire. I've been told you want to watch for contact with the engine. I've even heard of arcing between plug wires and the block. I figure it could fail quicker if this was happening leading to your little light show and poor idle.
Re: Anybody ever heard of this? [Re: Cochip] #876232 03/24/08 11:16 PM
904runner2dr Offline
Buy a factory set,install and enjoy.
Re: Anybody ever heard of this? [Re: 904runner2dr] #876233 03/24/08 11:26 PM
W
whitetoy Offline
I agree. You won't believe the difference in quality between the best aftermarket to the standard toyota wire set. Pricey, but worth it if you are having ignition issues.
Rick
1984 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6019 MB (Peak: 0.6667 MB) Data Comp: Off Server Time: 2026-06-10 17:58:03 UTC
