Need extended wheel studs for T100 #876311 03/19/08 07:57 PM
W
white_boy Offline OP
Long story short. I got some used 18X10 wheels with 33X13.50 tires with 4 1/2 back spacing. I have a 4 inch lift kit. The tires fit fine in the back but I need about 3/8-1/2 inch (aobut 4 washers stacked up works fine <img src="/forums/images/graemlins/scared.gif" alt="" />) in the front. I bought some 1 1/4 inch spacers and they are WAY too wide and the tires rub the snot out of everything. I can get 1/8 and 1/4 wheel spacers but I can't seem to find longer wheel studs. The stock ones are about 12.5x1.5 thread with a 14.2mm shoulder and 40 mm long. I figure I need about 50 to 55mm to work. Any of you guys had to do this? Where did you find the extended studs? I think ARP has some but it would cost me over $100 for 12 studs <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/baby.gif" alt="" />
1997 T100, 3.4 extracab, 5 speed, 4x4,
4" ProComp Lift, ProComp SS Skidplate
Fiberglass sprayed in bed liner
Re: Need extended wheel studs for T100 [Re: white_boy] #876312 05/01/08 10:13 PM
W
bump,
nobody has bought extended wheel studs?
Re: Need extended wheel studs for T100 [Re: white_boy] #876313 05/02/08 12:50 AM
BamZipPow Offline
A quick search on the web produced many companies that can sell you what you look fer.
Option Imports has 3 options fer longer studs all fer $2.55 each:
50mm, 45mm, 35mm...
Here's a set of 16 on eBay fer $44 shipped...although they are about 82mm in length. <img src="/forums/images/graemlins/wink.gif" alt="" />
Have you tried AutoZone, NAPA, or any of the other auto parts places? <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 2.155s Queries: 15 (0.003s) Memory: 0.5948 MB (Peak: 0.6481 MB) Data Comp: Off Server Time: 2026-06-06 20:25:39 UTC
