T-case Question. #876364 03/19/08 08:31 PM
Misha80 Offline OP
Ok, the raider I bought was towed back to the previous owners house. WHen I picked it up he told me it hadn't been moved since it was towed. When I got in it the t-case shifter was in 4l. Right now I have the tranny/tcase assembly out of the vehicle. Is there anyway to check the transfer case functionality without cracking it open? Like if I put the clutch disk on the input of the tranny and shifted through 2H, 4H, 4L, would I be able to tell if everything is working? And if I do have to open it up, what should I check other than things that are obviously broken?
TIA
Mikhail
98 Grand Cherokee 5.9 (Using 10% of the nations gas daily)
95 F-250 (The other 90% of the gas)
95 Honda Del Sol V-tec (Corner Carver)
Re: T-case Question. [Re: Misha80] #876365 03/19/08 08:45 PM
Yes. Take the driveshaft and slip it on the rear output shaft, and turn it by hand to see if the gears work ok, smooth, no binding. Drain the lube, letting the draining lube juice run over a magnet, and check for lots of metal. Minor fine metal power (too fine to feel any grain) is probably ok. Move the h/l shifter fork (the one on the right, I think) to engage low range, and check for about 2:1 diff in input and output rotation speeds. Engage the 4wd shift fork and make sure the front output shaft turns with the rear output at the same rate. Try to move the output shafts and input shaft axially (fore and aft) to check for bearing wear. Should get no movement. Replace output shaft seals.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5878 MB (Peak: 0.6361 MB) Data Comp: Off Server Time: 2026-06-13 13:19:45 UTC
