OEM/aftermarket clutch kits #876505 03/20/08 06:05 AM
Jeepeater Offline OP
Any favorite brands to use?
Anything to stay away from?
It's going in a 92 22re 5speed manual. I did search and only found results for Marlin. Any additional info is appreciated.
Thanks!
Re: OEM/aftermarket clutch kits [Re: Jeepeater] #876506 03/20/08 06:30 AM
kewlynx Offline
I've used NAPA's with no problems. Just make sure you take your flywheel in to get touched up.
**ubi apis- ibi salus**
Re: OEM/aftermarket clutch kits [Re: kewlynx] #876507 03/20/08 05:17 PM
Thanks M. My Toyota mechanic told me to get one from Kragen, Napa etc instead of a Toyota clutch-he said Toyota is using a remanufactured clutch and that it's junk. I just found this hard to believe. I've got a Napa across the street so I don't even have to thumb a ride! I talked to Tod yesterday and have the street RV head with a 261 cam on the way too... <img src="/forums/images/graemlins/kewl.gif" alt="" /> This rebuild is getting more expensive by the minute, but I guess it comes with the territory.
Thanks for the scoop!
Re: OEM/aftermarket clutch kits [Re: Jeepeater] #876508 03/21/08 05:47 AM
Vanishing_Point Offline
The first clutch I put in my truck was from Carquest. I don't know whether it was the brand or if I just got a bad pressure plate but when I loaded up the drive train the clutch didn't want to fully release (When I pulled a trailer or loaded up the bed). It would drag slightly. I went with a Napa clutch kit and the problem went away. I installed a $30 ebay clutch kit for a friend and it's worked fine for a couple years now. If I had to buy one I'd probably go with one from Marlin.
Re: OEM/aftermarket clutch kits [Re: Vanishing_Point] #876509 03/21/08 03:12 PM
G
Greg_Canada Offline
My Marlin has been great, it has greater clamping force than stock, and he offers quite a few choices and the price is reasonable.
89 4Runner
Re: OEM/aftermarket clutch kits [Re: Greg_Canada] #876510 03/21/08 06:23 PM
missouriman Offline
I have a center force 2...
do over,, marlin. period.
Re: OEM/aftermarket clutch kits [Re: missouriman] #876511 03/24/08 03:51 AM
KiwiCowboy Offline
I also have the centerforce and not a problem with it. Get the kit and replace the clutch, pressure plate and throwout bearing. If you've never changed out your clutch cylinder, replace it too. They are very inexpensive and since you're in there anyway, might as well.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6143 MB (Peak: 0.6885 MB) Data Comp: Off Server Time: 2026-07-16 11:50:13 UTC
